Laser Type Photo Tachometer
  • Laser Type Photo Tachometer
    Hi,
    Anyone use one of these?
    Looks like you apply a piece of reflective tape on a rotating part and point the laser at it to take a measurement.
    A Couple Examples:
    Extech
    Extech 461920 Mini Laser Photo Tachometer Counter | eBay
    Cheapy:
    Non Contact Tach Tool RPM Handheld Digital Photo Laser Tachometer Tester | eBay
    Bobby, www.TysonTone.com
    There's also a few Tach apps for the iphone. They strobe the flash led and you adjust the strobe period to make the marker stay still and then read the rpm.
      Originally posted by Beef Coon View Post
      I've have had one of those Cheapy units for for 2 or 3 years. Works just fine, especially for the price. I've used it to double check the rpm of the winder and traverser on my mechanical winder from time to time and it compares very close to the actual tach(s) I have on that winder. No need to use it on the CNC winder though. From time to time, you'll find the odd other use for one of these. I actually used it to calibrate the X-axis drive power feed control unit on my milling machine.
      Take Care,
      Jim. . .
      VA3DEF
      ____________________________________________________
      In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
        Cool, thanks.
