From the parts list, 10k linear. PV part number is 71190336. get it from the factory or any PV parts supplier. It is a voltage divider, so most any value will work. But it is one of their spider pots, so you really want to just get the real part.
Thanks for the quick reply!
I'm actually building one for a friend so I'm not going to need the real part.
Just to check - all relays as shown are in Crunch mode /RY3 is on, RY1 and RY2 off/?
My guess about Crunch mode was based on the fact that Switch 2A connects to the 470k/220p combo which means less attenuation /Crunch/ than 2M2/470p.
In my case it's not of big difference because I made 3 separate channels with their own tone controls and my clean channel is Fender type - I take the signal from V1B directly to R17.
