Unknown transistors , 5 pin???
  • Unknown transistors , 5 pin???
    Hi
    This is my first thread, so i hope it isnt in the wrong category.
    A friend of mine brought in a Proel Next 15 A active speaker. On power on the protect light doesnt turn off- it stays in protect mode.
    There are two output transistors for the LF part, and appear to be short-ciurcited/burnt. I measured a short between 2 pins.
    The thing is i cant find any info on what type transistors they are. The markings on them are SAP16 PO 3725 and SAP16 NO 3718.
    Here are the pictures of the transistors/ICs.
    https://scontent-b-fra.xx.fbcdn.net/...93290207_n.jpg
    https://scontent-b-fra.xx.fbcdn.net/...60304028_n.jpg
    Any help will be greatly appreciated
    they are Sanken Electric Darlingtons I believe
    SAP16* datasheet & application note - Datasheet Archive
    here is another tale of woe
    Help Troubleshooting a blown amp (SAP16) - diyAudio
    replacements are about $5 each from DK
    http://www.digikey.com/product-searc...376376?k=STD03
      Better to replace those with STD03N/P. Add external emitter resistors. Much more reliable than lousy old SAP's.
        Google SAP16N & SAP16P.
        You will find the datasheets.
          Looks like the SAP16N was obsoleted 5/31/2007 try STD03N from Sanken as well - available at Digikey. Please check the pinout and specs.
            Being aware that a ballast resistor (which was internal to the SAP16) must now be added to the circuit.
