Well, after reversing the bias cap my amp worked, but I´m having this little problem now, my guitar volume pot is scratchy with this amp, so I looked for DC at the input of the amp and it was there, -0.8VDC in stand by and -0.3VDC with the amp on. I tried changing tubes but the problem is still there. What can be the problem? What should I check first?
DC at the input, scratchy guitar volume pot
what guitar? what amp? link to amp schematic? does the guitar have onboard electronics?Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by R.G. View Postwhat guitar? what amp? link to amp schematic? does the guitar have onboard electronics?
The only other mod is the lar mar PPIMV, otherwise is just like this schem.
EDIT: I also conected the standby switch after the rectifiers, so the bias voltage is present even with the amp on stand by, unlike this schemLast edited by Silvio55; 06-02-2014, 05:19 PM.
That helps. Check and see if your 1M resistor to ground at the amp input jack is open.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Just so I'm clear - the amp has 0.6 to 0.8V DC on its input jack just sitting there? And the 1M pulldown on the input is OK?
If thats true, try swapping in another tube for the input.
A voltage of 0.8V across 1M is a current of 0.8V/1M = 800uA. It's coming from somewhere, and if there is no other connection to that resistor, it's coming from the tube. Er - you *have* checked for undesired other stuff connected to the 1M, not just the tube and the input jack, right?Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by R.G. View PostJust so I'm clear - the amp has 0.6 to 0.8V DC on its input jack just sitting there? And the 1M pulldown on the input is OK?
Hmmm... next I'd check for a shorted/leaky cathode cap on the input tube(s). Pull the cathode caps of temporarily on the input stage. If problem goes away, it was a bum cathode cap. If this doesn't help, I'm down to looking for tagboard leakage.
Or maybe it's haunted.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Just to add to the confusion, 0.8uA = 800nAIf it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by R.G. View PostHmmm... next I'd check for a shorted/leaky cathode cap on the input tube(s). Pull the cathode caps of temporarily on the input stage. If problem goes away, it was a bum cathode cap. If this doesn't help, I'm down to looking for tagboard leakage.
Originally posted by Silvio55 View Postwithout 68k gridstoppers at the input, jack connects straight to V1 grid through a shielded cable, and the ground point is right at the input jack (I used this method as recomended by Paul Ruby and worked fine with my other amp, no noises, no scratchy pots)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostDo you have that other amp, if so try that exact tube in this amp. Perhaps with the lack of gridstopper it is extra finicky about the V1 tube and maybe you just got lucky in the other amp. You might also want to see whether a smaller gridstopper (10K or so) cures the problem.
