Vox AC 30 Voltage and popping problem.
  • Vox AC 30 Voltage and popping problem.
    Hi guys,
    Are these voltages normal for VOX AC30? I rebuilt this amp with new board and parts to original ac 30 chassis.
    32V DC at PI grids when working, -550mV at 2 of EL84's grids when standy by.
    In addition to these, amp is popping when i hit the cabinet. And also harshness sound at high volumes (vibrating cabinet).
    Could you help me please? Could you show me the way? I can post photo or video, make voltage or scope readings as you want.
    Thanks. Okan
    So you have -550mv only on V5 and V7? not on the V4 and V6?
    What kind of voltage are you looking at on all four EL84 grids when out of standby mode?
    Maybe you should look at this:
    http://www.ampbooks.com/home/classic...c30-power-amp/
    1937 Gibson L50 "Black Special #4"
    1978 Gibson Melody Maker D Reissue
    2004 Ibanez SZ720FM
    Epi SG '61 with 490R & 498T Pickups
    Couple Marshalls, Crate Blue VooDoo
    Couple 4x12 cabs
    Couple Orange combos
    TONS OF FREAKING TEST GEAR- SCOPES, METERS ,ANALYZERS
    SIG GENS, ETC, ETC, ETC.
      Please post the complete schematic of your build, including the standby arrangement.
        You often get silly readings when measuring the PI grids. Try measuring the the common PI cathode connection. I measure 60V there which is similar to the voltage marked on the AC30 schematic.
