POD HD desktop RJ45 (FBV pedal) PCB
  • POD HD desktop RJ45 (FBV pedal) PCB
    Hi, unfortunately damaged cable made a short circuit on RJ45 socket for FBV pedal. Unit works still OK but choke between L18 and L22 was burned and so pedal doesn't work. There's right voltage about +8V DC on one side burned choke and I can also find other side burned choke going to RJ45 socket what is power supply for pedal. It isn't problem replace this part for me, but I'm not sure if other roots or parts on PCB near burned choke and RJ45 socket wasn't damaged. Please has anybody an image of PCB near RJ45 socket for this unit ?
    I thank You at advance.
