Results 1 to 16 of 16
Thread: Alien Monster 6l6 50W
    New Member
    Aug 2014
    1
    0
    Check out this cool amp from Alien
    http://www.youtube.com/watch?v=RIll5D4WUy8
    Feb 2010
    11,308
    Received: 1,268/21
    Given: 3,163/8
    22
    Please post promotional material in the "plug your product/service" area here: Plug Your Product/Service
    In the guitar amps section posts like this are considered spam.
    Old Timer
    Oct 2011
    1,951
    9
    I don't think I can comment on the sound of the amp. It sounded quite obvious to me that there is either effect pedal and/or special effect in the recording. Once you have that, you really are not listening to the amp.
    Case in point, I heard a lot of fantastic demo of the JCM800 2204. But when I look at the schematic, I don't see how it can have enough gain at the preamp to get any reasonable distortion. I since build the whole preamp section into my Bassman platform. Sure enough, I cannot get any meaningful OD unless I crank the whole thing way up to get the power amp distortion.
    I tested quite a few amps including Mesa, Peavey, Fender, Marshall, PRS and some I forgot the names, if there is no pedal in front of it, they sound nothing like the demos.
    Maybe, it's better to say whether the amp can take pedal well or not!!!
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,268
    Received: 1,456/18
    Given: 1,106/27
    26
    You donīt?
    Please post the preamp schematic you built.
    Donīt link to Marshall site and say "this one", draw what you actually built.
    Some picture would also help.
    Amazing.
    Which input are you using, normal or high gain?
    Old Timer
    Chill-Ville, VA
    2,988
    Received: 553/4
    Given: 1,005/9
    16
    I'm with Alan on the "where's the pedal?" Not for the gain, but where's the trem & flanger/phase effect coming from? I'd know a lot more of what the amp was capable of in a non-band setting. All I mostly saw was guitar neck & player's head. Like the song, nothing bad to say about the amp, but definitely too slick for me to make an opinion on. Strip it down to guitar-cord-amp, all in plain sight, then we're talking!
    Justin
    Old Timer
    Oct 2011
    1,951
    9
    You donīt?
    Amazing.
    I build the 3 stages exactly like the 2204. I even make sure the voltage at all points are reasonable close to the schematic also. That is like driving the HI input. It is exactly the circuit, every single value of the components are the same. I don't have a schematic drawn as it's just the exact copy.
    If you look at the second stage with cathode resistor of 10K without bypass cap. That makes the gain of the stage lower. If I bypass the 10K, at least I get more OD. I use new JJ 12AX7 also, so tubes should not be a problem.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,190
    Received: 752/32
    Given: 744/14
    21
    I've built two of the JCM800 2204 cascade amps, one with EL34s w/marshall type Iron, and one with 6L6s w/Fender type iron.
    They both had tons of drive.
    Make sure the cascade low and high jacks are wired correctly.
    On High you should have 1b tied to 1a through the jacks.
    Another key factor to gain at low volumes, is the additional PPIMV.
    I wouldn't want a 2204 without both pre and post MVs.
    I built both into the front panel on both of my amps.
    T
    Courage is being Scared to Death, but Saddling up anyway! (John Wayne)
    Jun 2006
    California, USA
    3,554
    Received: 134/0
    Given: 90/1
    17
    Alan,
    I agree with the others that you should have been able to get lots of overdrive type distortion out of the circuit you intended to build. I remember thinking when you originally posted the results that something must have been wrong because the cascaded version of the Marshal pre-amp in the 2204 should have lots & lots of gain.
    Tom
    Old Timer
    Oct 2011
    1,951
    9
    Quote Originally Posted by big_teee View Post
    T
    I wired to totally bypass the low gain jack. I just drew out the schematic and attached here. It is just the 2204 driving the Hi input.
    BTW, I use Strat with lower output pups, not the high output HB guitar. That can make a day and night difference.
    Jun 2006
    California, USA
    3,554
    Received: 134/0
    Given: 90/1
    17
    Quote Originally Posted by Alan0354 View Post
    I wired to totally bypass the low gain jack. I just drew out the schematic and attached here...
    Alan,
    That circuit you posted is two gain stages and a CF then you show the output of the tone stack driving the PI.
    That is not the Hi Gain Marshall preamp the other guys were talking about. The Marshall Hi Gain setup includes an additional gain stage.
    Tom
    Oct 2007
    11,268
    Received: 1,456/18
    Given: 1,106/27
    26
    Thanks.
    Don't know about your guitar but the schematic you posted sings all night long with humbuckers and provides more than a nice crunch with any normal Strat.
    You didn't write the 2nd triode plate resistor value but I assume it's 100K.
    That said, try the PPIMV suggested by Big Tee, you'll like it.
    @Tom: Alan shows 3 gain stages and a CF
  12. #12
    Jun 2006
    California, USA
    3,554
    Received: 134/0
    Given: 90/1
    17
    ...Tom: Alan shows 3 gain stages and a CF
    Opps. Now I see the third stage. So, Alan, it remains a mystery to me why you didn't get lots of gain to spare out of that circuit.
    Tom
  13. #13
    Old Timer
    Chill-Ville, VA
    2,988
    Received: 553/4
    Given: 1,005/9
    16
    ??? Is the third (actually the first) stage implied? Where it says "input?" Just trying to learn here... If I'm missing something?
    Justin
    Found it... funny what you see when you're tired.
  14. #14
    Old Timer
    Oct 2011
    1,951
    9
    Thanks.
    Yes, it has crunch, just not rich OD. Yes, I'll experiment on that.
  15. #15
    Old Timer
    Oct 2011
    1,951
    9
    Quote Originally Posted by Tom Phillips View Post
    Tom
    Maybe is just different interpretation of "OD" and high gain. I never feel there's enough gain with 3 stages. I use 1.5K bypassed by 0.22uF at the cathode of the second stage and 1uF bypass the 820 cathode resistor of the third stage to get enough OD for my taste.
    Actually that was the reason I actually build the 2204 front end to hear it with my own ears how people keep saying it's the standard of high gain amp by which other amps are being judged.
  16. #16
    Old Timer
    Oct 2011
    1,951
    9
    I think we hijacked the thread too much. Let's get back to the OP. I just don't like people demo amps with effect added. I don't even like people putting reverb. The only true demo is guitar into amp through a single jack. You have anything special, show it that way. I did not listen pass 2 minutes because it bored me.
    The sound sounded good enough......so as a lot of demos of other amps. If this is to attract me to buy this amp, it definitely failed big for me.
    To me, this is a good demo for the DSL40C.....whether you like it or not.https://www.youtube.com/watch?v=9vkMUrxzZ8k.
    I got very close to the sound in the store with my guitar plugged straight. To me, this is a true demo, that I get the real feel of the amp.
    BTW, I really like this Marshall.
  1. Monster Pro 2500 High Pitched Whistle
    By Danlampton in forum Music Electronics
    Last Post: 06-05-2017, 11:38 PM
  2. Two-headed monster
    By dkevin in forum Theory & Design
    Last Post: 04-12-2011, 05:48 AM
  3. 6L6 to 6550 conversion for Fender 45/50w amp
    By Jazz-O-Sonor in forum Mods & Tweaks
    Last Post: 01-26-2011, 03:28 AM
  4. Fender Pro Jr Monster conversion
    By Music Fox in forum Conversion Projects
    Last Post: 03-15-2009, 09:22 PM
  5. Monster Mudds newest disasters.........
    By dazzlindino in forum Pickup Makers
    Last Post: 10-18-2008, 09:32 PM
Tags for this Thread
