Help Biasing BRYSTON 4Be
I haven't talked to them for a long time but last time I did they were very helpful.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I cannot make out any test points.
Everything is smudged.
Anyway, as far as I can see the 2K trim pot is the bias adjust.
The 10K trimmer appears to be a DC offset adjust.
I don't think either will help if one side is hotter than the other.
Bias checking would be accomplished by measuring across the 0R15/ 5W ballast resistors.
I would measure those two points before doing anything.
You want to see millivolts.
No signal, no load.
The 4BE name became 4B NRB. I've read that the bias is set the same as the SST, but suggest you check with the factory. The 1K trimmer should be the bias adjust.Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Jazz, I read it as one side as in one channel is running hotter, not one side of a particular channel. The bias trim ought to help that.Education is what you're left with after you have forgotten what you have learned.
Well i start by measuring the 0R15/ 5W resistors, in the left channel of the amp (the good one) i get around 15mV on each resistor, now in the right channel i measured 30mV on the + side and around 65mV on the negative side resistors, so i get my screwdriver and turn the bias pot one millimeter, and then the mains fuse blow up, and now i got 2 shorted output transistors
So, i think the next step is to replace all output transistors (BR6521/BR6522) with a decent replacement maybe MJ15024/MJ15025?? what you think??
thnks!
Those should work fine as subs. Start the bias all the way off and bring it up slowly after replacing the shorted outputs.
Edit: You may also want to build a light bulb limiter until you get it working to save yourself making a pile of shorted transistors.Last edited by The Dude; 09-10-2014, 01:09 AM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Bryston Bias Pots
Originally posted by The Dude View PostThose should work fine as subs. Start the bias all the way off and bring it up slowly after replacing the shorted outputs.
Originally posted by Dandy Don View PostBryston says they haven't had problems with their 2.2k ohm bias pots that are used in many of their amps, but in my limited experience, I have had two amps blow output transistors due to bias issues. Corrosion occurs at the wiper arm pivot (see the photo). In most of my amps, I have replaced the bias pots with multi -turn sealed Bourns pots. The only thing is you have to be certain to set the pot to give minimum bias current before powering up. The original pots can be modified as shown in the photos to act as a carrier for the Bourns 3299 model pots.[ATTACH=CONFIG]33447[/ATTACH][ATTACH=CONFIG]33448[/ATTACH]
Originally posted by angelothewolf View PostThanks Dandy Don, yesterday arrived the full set of mj15024/25 transistors from Mouser. i replace all transistors on both sides of the amp and all electrolitic caps. unfortunately i have several transistors shorted again. i was trying to set bias, one channel at a time, with light bulb on the mains. measuring mV from V+ to test point on the emitter resistors, i started on the begining of the trimpot reading just a few mV, then pfff shorted, maybe i have that trimpot problem, what you think?
Check your pots with the power off using an ohm meter connected between the wiper and one of the other terminals. It should change smoothly as the pot is turned. If it is jumpy, turn the wiper back and forth several times. If you have contact cleaner with a lubricant, this would be a good idea. If there is a bad contact, it will likely be in the wiper pivot, not where the wiper contacts the resistive element. Since the Bryston bias pot is exposed to the atmosphere, this is why I like change them for sealed pots.
If you can't figure it out, send it to Bryston. Their service is excellent. If your amp is over 20 years old, it won't be under warranty, but in my experience they do great work at a very reasonable price. And they fully test amps after they repair them.
Originally posted by Jazz P Bass View PostIt would be a better approach to ditch the limiter when trying to set the bias.
i was reading the same ¨tech reference¨ sheet that J P Bass suggested, wich indicates seting the bias around 4mv to 6mv, but my measure never drops below 10mv, so i think ive got another problem here...
thanks!
You'll want to check over the entire circuit THOROUGHLY before you fire it up again. Check for open resistors, shorted/open driver transistors, etc. Spend some time checking the rest of the amp and not just the outputs. It'll save you some grief. Also, when you do fire it up again and before you touch a bias pot, measure the output for DC (no speaker). If you detect any DC at the output, there's no sense fiddling with bias. The amp is still broken.Last edited by The Dude; 04-01-2015, 10:35 PM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
