Originally posted by MarkusBass
View Post
Crate VC5310 power tube failure ,and fuse blown.
Originally posted by MarkusBass View PostOn the schematic there is a jumper from cathode of the power tubes to the ground. You can disconnect it and replace with a meter set to DC current (range 200 mA). And report what current you get. This will tell you whether the bias is set correctly.
Mark
You shouldn't need them all in.
So you clipped the J03 wire and have your meter connected between the two sides of the clipped wire? Do you have your meter set for DC current range with the probes in the proper ports for current measurement?
Is it auto-ranging or do you have a choice of range (200mA would be good) ?
Does the meter have a fuse for current range that may be blown?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Your meter needs to be set to DCA or DC mA, not DC volts or millivolts. You said there is a 200mA jack for the probe so it must be able to measure current.
And be sure to take the probe out of that 200mA jack as soon as you are done. If you forget, your meter will be a dead short between the probes and fry something when you try to measure volts.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostYour meter needs to be set to DCA or DC mA, not DC volts or millivolts. You said there is a 200mA jack for the probe so it must be able to measure current.
Originally posted by gtrplayr1976 View PostThis is how I set the meter.
Mark
