Originally posted by g-one
View Post
Crate VC5310 power tube failure ,and fuse blown.
Originally posted by g-one View PostYes. Then check so full counter-clockwise gives max resistance of the pot. That way turning clockwise will make tubes run hotter.
You want to keep the series resistor. That way even if the pot gets turned to 0 ohms by accident, you still have the series resistor so you still have some bias and the tubes don't burn up.
Untill you verify it's working right, remove the power tubes. Check at pin2 of the power tube sockets that the -DC is changing when you adjust the pot. It should go from somewhere around -15VDC to more negative depending on the pot setting.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostYou want to keep the series resistor. That way even if the pot gets turned to 0 ohms by accident, you still have the series resistor so you still have some bias and the tubes don't burn up.
See what kind of DC variation you are getting at pin2 with power tubes out. What is the value of your pot?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Yes, you should see current variation at J03 (same conditions as before, Jumper lifted, current meter in series, good fuse).
But there must be voltage variation at pin2 of power tube sockets, this you can check with them out of amp.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostYes, you should see current variation at J03 (same conditions as before, Jumper lifted, current meter in series, good fuse).
In case there is a schematic difference from your amp, verify that R78 is going where the schematic shows.
What was your voltage reading (that wouldn't change) on pin2 ?
Edit: Try the pot in series with a 5K instead of the 15K and see if you get voltage variation at pin2 (power tubes still removed).Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostIn case there is a schematic difference from your amp, verify that R78 is going where the schematic shows.
I hope you mean negative 13V at pin 2 .
I'm not sure the exact alternate wiring you are speaking of without a schematic. If they meant disconnect the top of R78, put in series with the pot, other end of pot to R77, disconnect R77 from the bias filter cap which then connects to the pot wiper, then yes.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Here's the 2 alternate circuits drawn out. The #2 option may be less desirable as it effectively increases R77 at the same time it is effectively decreasing R78. Doing both at the same time may cause the pot to be more "touchy" as they both decrease the bias voltage. Method #1 does not increase the effective series resistance of R77.
In chosing between those two, consider what happens if the wiper contact fails in the pot.
Hint: I never take bias off a wiper.Education is what you're left with after you have forgotten what you have learned.
