Weak tremolo
  • Weak tremolo
    Got a blackface Deluxe reverb with weak trem.
    The oscillator circuit seems fine, would the roach cause this?
    Any other usual suspects?
    thanks.
    Could be the tremelo cap. Which model is it ? If it has the neon and thermistor see if it's blinking when you turn the speed and intensity up.
    KB
      Twas the roach.
      It was blinky blinky alright, but had a high resistance on one side that measured about 60k on a good one borrowed from a Twin Reverb.
      popped the good one in and it works nice.
      In 20+ years of amp fiddlin' it was my first bad roach in a Fender...of course it is a 40 yr old amp!
        Sometimes you can ohm out that thermistor I think it should be about 120 ohms. Check both and you could use it for a reference check. I haven't seen to many of them go either when they are blinking right.
        KB
          Isn't that a photo-sensitive resistor? IIRC the max resistance is usually around 2 Megohm. I don't remember the minimum resistance.
