Working perfect before, turned it on today and very low output on normal side, no output on bass side. Nothing obvious/loose in the chassis. Tubes are good, checked and changed both (pre-amp and power) them. I'm at 425volts and 48ma on both output tubes. I'm thinking its a bad cap or open resistor, I've looked at the schematic and checked what I could. I'm at a loss as to what the problem is. Any ideas?
66 Bassman head stock, low output normal, no output bass side
Originally posted by pintail78 View PostEverything checks out normal....but pin 8 (coming off the 25/25 caps, parallel 1500 resistors) on V1 and V2 are reading 350 volts instead of 1-2 volts.....I think have it pinned down to the area thats messed up but not sure yet. Any ideas???
Then check the resistance of that 1k5 resistor. It seems to me you are getting the HT on the cathode.
Originally posted by pintail78 View PostEverything checks out normal....but pin 8 (coming off the 25/25 caps, parallel 1500 resistors) on V1 and V2 are reading 350 volts instead of 1-2 volts.....I think have it pinned down to the area thats messed up but not sure yet. Any ideas???This isn't the future I signed up for.
Funny last night I keep looking at that ground on the schematic just before bed......then I read all your suggestions. It was a bad ground, fired up perfectly after resoldering. I'm going to give all those grounds a yank with the needle nose today before I zip it back up. Thanks for all your help! John T.
That was one of the problems with my 63 Bandmaster all that was wrong the ground wire to the buss bar had coroded under the solder joint..Kendricks amps got me for $1300 and never fixed it just pulled every thing else out.....If you can't find the problem send it to Skip Simmons amp repair,he fixed it in 10 mim and only charged me a few dollars...
$1300 and never fixed it? Damn 1300 ain't right even with fixing it. Personally my conscience wouldn't let me charge someone for troubleshooting something that I never repaired, other than the normal 1 hour bench fee. If I had that much time in it I would damn sure find the problem so I could charge for at least some of those hours, but that's just me
Originally posted by dumbassbob View PostThat was one of the problems with my 63 Bandmaster all that was wrong the ground wire to the buss bar had coroded under the solder joint..
SJ, it's an old shaggy dog story around here, DAB was going thru hell with his amp and Skip finally found the real problem which was cheap to fix after lots of money & frustration at Gerald Weber's shop. You think the self-proclaimed "world's foremost authority" would know better, but no. Must have been 600+ postings, it would take a week to read it all. We're ALL very relieved it got repaired right.This isn't the future I signed up for.
Originally posted by Silvertone Jockey View Post$1300 and never fixed it? Damn 1300 ain't right even with fixing it. Personally my conscience wouldn't let me charge someone for troubleshooting something that I never repaired, other than the normal 1 hour bench fee. If I had that much time in it I would damn sure find the problem so I could charge for at least some of those hours, but that's just me--Jim
He's like a new set of strings... he just needs to be stretched a bit.
Hey guys,
Actually, The Man (Skip) who actually FIXED DAB's amp wrote aboout it in Vintage Guitar magazine... It was fun to see our saga here (no names mentioned) in a national publication. His advice was great: "get a second opinion!" And hopefully Bob can now drop the DA from his name!
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
