Easiest way to assemble/test proto dr504 amp?
  • Easiest way to assemble/test proto dr504 amp?
    I've been thinking of doing my first clone on a breadboard, stage by stage...preamp first. Going to do a dr504 clone.
    but obviously running 300 plus volts dc in a breadboard seems incredibly dangerous.
    Anyway I can do this with the preamp tubes (or something that will test similar?) and without killing myself?
    I asked my teacher today about his hifi build, but I've already forgotten.
    Thanks for any help.
    You can use a real breadboard, meaning a piece of plywood with (preferrably brass) nails embedded and somewhat thick (#18) solid wire working as ground and +HV rails.
    You get to solder everything and in general try not to cut parts leads, at least not too short, for removal/reuse .
    FORGET standard plug in solderless Protoboards, deadly at Tube voltages.
    NO:
    YES:
      Fantastic. Thanking you.
