More Pwr and Headroom for SF Champ
  • More Pwr and Headroom for SF Champ
    Hi-
    I'm new here - Happy to have found this site.
    I have a SF Champ. I am looking for ways to increase the power AND headroom. Most mods seem to make things dirtier - I want to go the other way.
    Heres what i have going currently (btw my guitar is an G&L ASAT w/ the p-90 style MFD pu's).
    Stock 8" alnico spkr, 5V4 rectifier(for more headroom) 5751 preamp and RCA 6V6. Original filter caps - soon to be replaced.
    The amp sounds great this way but the bass response isnt happening and the spkr while it sounds good lacks bass response and is a bit farty
    I know replacing the cap can will tighten things up.
    What about removing the feedback loop? With it add more pwr or just make things dirtier?
    Same for tone stack? I like to be able to adj the EQ - at least the treble
    does running the tone knobs at 10 achieve the same things as removing the tone stack?
    I've heard some guys replace the 6V6 with a 6L6 for more pwr - but I've heard that its not good for the Pwr xfmr - I know to increase the voltage rating on the bypass cap to 50V if I do this.
    Any other tube substitutions for more pwr & headroom?
    I plan on replacing the spkr w/ either a 10" weber or 8" Jensen - are the MOD series decent?
    I want to stick with the combo package - ie no separate cabs.
    What about biasing? I know these amps are cathode bias but I suss that installing a variable bias control or biasing it a certain way is probably key to my achieving my goal.
    Any info/help much appreciated.
    Thanks in advance!
    JPH
    Hi JPH.
    Well, you pretty have it sussed. Don't remove the NFB, it'll make things dirtier, but also increase a bit the volume. I think the best way would be to make it fixed bias, use a 6550, change the output trany to cope with thoses, use GZ34. And obviously change your caps.
      Thanks!
      I credited the wrong person for your 6550 suggestion - my apologies...
      How much pwr can be gained by doing this? what kind of OT?
      Cheers,
      JPH
        As per http://tdsl.duncanamps.com/tubesearch.php
        up to 20 watts with a 6550.
        http://www.mif.pg.gda.pl/homepages/f...35/6/6550A.pdf
          JPH,you have 2 threads going at the same time on this subject,maybe one of the administrrators can put them together somehow?
