flat pickups 3 mm
  • flat pickups 3 mm
    https://www.youtube.com/watch?v=0QaHpTYMY6c
    the pickups are constructed using two sheets of thin steel, cut to size,
    * between 2 plates are placed sendwich type neodymium magnets.
    in such ways is realized built the coil, the inner surfaces of the coil are insulated with plastic film.
    * is subsequently made ​​the winding wire 42 AWG,
    connect the plates to the ground,
    beginning coil and plates connected to the ground.
    lateral edge plates welded together for greater structural strength.
    the functions of the plates are twofold
    * - Form the coil - make up the structure of the shape of the pickups, contributing to the strength of the pickups.
    shielding against interference - soften and conform the magnetic field.
    length 12 cm
    width 3 cm
    0:27 cm thick +/-
    low resistance, low impedance, high output sound
    sorry for English
    http://surdopickups.blogspot.it/
    Welcome Antonio,
    That's pretty impressive to me though it's hard to tell how much sound is coming from the sound-hole and how much from the amp. Can they be bent to follow a radiused fingerboard?
    Humbucking?
      Hello David,
      nice to meet you.
      you're right, look for the video as soon as possible publish other saw, some musicians are using the pickups.
      Other comments and opinions will be added.
        the pickups can not be bent, because of all the building structure including magnets.
        it is a single coil
        low impedance
        I would define HI Fi
        Despite the musicians say that it has a high output, I would rank among the output pickups to medium-low.
          undoubtedly is the original building, including the size, and the technique of fixing
          https://www.youtube.com/watch?v=FPWHI-NMD3A
          hello David
          we update
          regards
