Results 1 to 22 of 22
Thread: Octave effects and amp damage?
    Sep 2008
    Prince Edward County, Ontario, Canada
    350
    Received: 1/0
    Given: 1/0
    12
    I was trying out a new bass octave effect pedal today with my home designed/built bass amplifier. The amplifier uses 4 6550 power tubes and puts out around 160W. My homemade speaker cabinet is a 4 x 10 sealed non-ported cabinet with each speaker rated at 150W for a total of 600W. I have two of these amplifiers which have been in regular service for years without any problems to speak of. I play a 4 string bass in standard tuning.
    About 20 minutes into my trial with my new octave pedal one of my power tubes fried. I did a google search to see if any others had had a problem like this with an octave pedal. Not much turned up but there was a case where someone had this same problem with two different amps. It occurred to me that the low frequencies generated and fed into the amp from the octave pedal might cause more stress to the power section of the amp as it would be conducting higher average current over time. Same thing for the voice coils of the speakers. The low E would be generating a 20 Hz signal.
    Anyway, I checked that my bias voltage was still there (it was and was normal) and replaced the fried tube and tried again. I also had my multimeter set up measuring the average cathode current of the tube. I played for a full hour without anything breaking a sweat. The cathode current would increase a little when I played hard in the low ranges but it did the same way with the octave pedal turned off as well.
    My conclusion is that the octave pedal is a little harder on the amp and I happened to have a tube that wasn't 100% and couldn't handle it. I don't think my speakers are at any risk as they are in a sealed cabinet and have a combined 600W rating which is approximately 4 times the maximum power the amp puts out. However, I've dug up stuff on the internet about the risk these sub octave effects pose to speaker cabinets. I'd like to get input on this subject in general from people with greater technical knowledge which is why I'm posting this subject on this forum.
    I'd be interested to hear people's thoughts and wisdom on this subject.
    Thanks,
    Greg
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,021
    Received: 1,815/7
    55
    A comment: Everyone wants to find something to blame. They want every failure of an amp to be BECAUSE of something. They also like to cite past performance. This worked for 20 years, why would it stop now? Well, life isn't like that.
    Everything works until it doesn't, simple as that.
    But it happened when I as PLAYING??? Of course. Most failures occur when something is ON and in use.
    You had a tube failure. Tubes, new or old, can fail at any time. Like a big bug can fly into your windscreen at any time. They don't only do it on Tuesdays or only when the Everly Brothers come on the radio.
    You may have an FX pedal that makes 20Hz, but that doesn't mean your amp can produce it. Never assume. I'd be willing to wager that your tube would have failed even without the FX. It simply ran out of time on this earth.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,881/23
    Given: 1,463/35
    27
    Agree and add.
    Besides your particular failure, which neither I find related, octave pedals are nonsense (sorry) in a Bass.
    Starting with the sad but true fact that standard speakers do not reach even 40 Hz flat , what we hear when playing the lowest open string is its harmonics and our brain reconstructs the fundamental, so sending them even lower frequencies simply does not work..
    For various reasons,all conspiring against us:
    1) below lowest frequency, sealed speakers drop at 12dB/oct ; tuned a scandalous 24dB/oct
    2) they require 4X the excursion per octave we go down.
    3) The longer coil needed further lowers efficiency.
    4) we hear less at such low frequencies .
    One amp which incorporates a bass octaver is the Ashdown ... famous for turning those oh so popular 2x10" bass cabinet cones inside out like a glove, no kidding.
    EDIT: this is the measured frequency response of an 8x10" cabinet, upgraded with Eminence Alpha 10 instead of the original ones:
    look at the catastrophic rolling down below ..... 100Hz !!!!!
    Look at the curve of the original Eminence BP102 "Ampeg 10"speaker" which matches the above one , the World's most famous Bass speaker drops like a rock below 100 Hz !!!!!!!:
    http://www.musiciansfriend.com/acces...w-bass-speaker
    Supporting Member
    Staffordshire UK
    3,767
    Received: 514/1
    Given: 468/2
    18
    My (sketchy!) understanding is that as frequency is moved down, the magnetic circuit 'headroom' decreases, and that when it saturates, the primary inductance (which facilitates the primary impedance) collapses. At that point the impedance transformer action will probably fail and primary impedance becomes the primary resistance, eg for this amp, a few ohms rather than a few hundred ohms.
    That might push the power tube plates into overdissipation and bring forward an impending failure mode?
    Perhaps repeating that current measurement test comparing 20Hz and 40Hz at full power would indicate whether the above was the case?
    Sep 2008
    350
    Received: 1/0
    Given: 1/0
    12
    Some clarification is in order. I'm well aware of the fact that speakers and cabinets can't reproduce very low frequencies well. That isn't the point here nor what I was aiming to do. You can put frequencies all the way down to DC into a speaker which isn't good for it as it can heat up the voice coil. You won't hear them but they may be doing damage which is the point here.
    This is exactly what I was thinking myself and why I posted this thread - to generate discussion on the possibility of octave effects damaging equipment.
    Yes, tubes do fail but from my own experience this isn't common unless they're either very old, new but defective, or being worked very hard. If you get past the first 10 hours or so with a new tube it should be good for a long time. Also, I bias my amps conservatively and don't push them hard at all. The probability of a tube that's only a year old and only seen light moderate use suddenly dying for no apparent reason is very low. Not impossible. My thinking was that it was a borderline tube that the octave pushed over the edge. However, as I said before, with my multimeter hooked up (after replacing the failed tube) the average current through the tube did not seem to increase any more when the octave pedal was engaged compared to when it wasn't. So it could have been a random coincidental failure.
    Jul 2012
    The 26th state
    589
    Given: 1/0
    8
    I did some amateur testing with what I can detect at low frequencies (since I play mostly bass and there were previous discussions about this) and after conferring with a friend that used to use and buy/sell high end audio gear he said the same thing that JM said - we can't actually "hear" the lowest notes of the range, but rather we hear the harmonics and our brains fill in the rest. So when someone claims they're hearing 20-40hz I have to wonder if they've done the research.
    As far as it damaging a tube, I'm no engineer and I don't have the decades of experience that some of our fellow members do but I guarantee it's more likely the tube just failed like Enzo suggested. These aren't precision instruments or parts, they are hand-made and there is always the potential of a failed part - ten hours or more aside - because of that. They're not absolute, every tube is slightly different in quality and durability. My gut says you had a bad tube, I've replaced many recently and they ranged from brand new to thirty years old and everything in between.
    As far as low frequencies causing the damage to the tubes, even with a higher current draw for more extended periods, I think that's like chasing a ghost. It's likely not anywhere close to the actual reason for failure. If the tube was weak construction-wise it would stand to reason the stress killed it. But if it were the low frequency itself why would it not take out the other tubes? I think the answer is right there, just a bad tube or other part that took it out.
    --Jim
    He's like a new set of strings... he just needs to be stretched a bit.
    Lifetime Member
    4,435
    Received: 424/1
    Given: 3/0
    21
    Power tubes are mostly internally current limiting, in the sense that it is very, very hard to make them conduct more current than a given "max". This is one reason that tube output stages are so tolerant of being loaded by less than the ideal plate to plate load. For most tubes, shorting a speaker output will not damage the tubes; at least not for a long while.
    As for running out of magnetic headroom - sure, you can saturate a transformer primary by feeding it too much volt-time integral (that is, too big a voltage at too low a frequency). But even there, the tubes have a strong tendency to self-limit in terms of current. There is always an issue with holding a tube at high current and high voltage across it for too long, and having it melt down. But that is what it is - heat damage. The plate goes red, then yellow, then something melts and the tube dies.
    But tubes are very tolerant of this, too.
    You didn't say HOW the tube died. Did the plate melt? Did the *glass envelope* melt? (I've seen that!) Did the heater go open? Did some elements short? Does the tube just not have enough emission? That would be an important set of knowledge for gaining insight into what happened. Is it possible that this socket has an intermittent grid bias?
    Then there is the issue of what AC signal actually got fed to the tubes. Most guitar amps don't respond down to 20 hz flat in the electronics. Preamp voicing usually rolls off the low bass well above there. So it's possible that even if the pedal fed the amp 20 Hz, the amp may not have fed this to the power tubes.
    I don't know which, if any, of these were at play. But to actually find out what happened, these kinds of things have to be checked. A very instructive thing to do would be to put in an new tube, instrument the amp so you could watch and record the actual voltage and currents in the output tubes under similar conditions. This could tell pretty quickly if they were even getting near the tube power limits.
    Sep 2008
    350
    Received: 1/0
    Given: 1/0
    12
    Thanks for your reply and input to the thread. To clarify, I did not claim to be hearing 20-40 Hz. I said the octave effect could track down to the low E on the bass and therefore possibly input a signal as low as 20Hz into the amp. Whether anyone can hear it or not is irrelevant to the topic of this thread.
    It came on very suddenly. I noticed the sound fade and when I looked at the amp the entire tube was glowing a very bright orange. I shut the amp off immediately. Nothing seemed to be very hot - not any hotter than normal, no melting of anything, no burning smell. The heater still works and there appears to be no obvious damage to the internal components. However, the glass now has a silver residue on one side that looks exactly like the same thing on the top surface of the glass. I can't quite remember the reason the top surface of tubes is like this but believe it has to do with some element being released during or shortly after manufacture. I tried the amp again with the failed tube and found it was only conducting 12 mA at idle instead of the normal 52 mA I had biased it at. The three other tubes were still conducting 52 mA. I don't think it's likely the socket has intermittent grid bias as it's a new high quality socket.
    [QUOTE]Then there is the issue of what AC signal actually got fed to the tubes. Most guitar amps don't respond down to 20 hz flat in the electronics. Preamp voicing usually rolls off the low bass well above there. So it's possible that even if the pedal fed the amp 20 Hz, the amp may not have fed this to the power tubes.[QUOTE]
    Good point. That makes sense.
    Actually I did exactly this and found that the tubes were nowhere near power limits. The average cathode current rose slightly over idle when playing but nothing major and no difference between the octave effect being on or off - which supports what you said about most of low frequency response being filtered out in the pre-amp.
    So hopefully that information I provided about the tube failure will provide more insight into what happened. I'm curious to know.
    Oct 2007
    11,753
    Received: 1,881/23
    Given: 1,463/35
    27
    Well, glowing a very bright orange. points straight at lack of bias.
    If only that tube did so, then it was not a general bias failure , so possibilities are:
    1) socket problem, pin 5 lost contact.
    ****Might***** be related to the octave pedal, in an indirect way: extra vibration shook the tube more than usual.
    2) pin 5 wire was improperly soldered inside the hollow octal contract at the tube base (I have seen this on cheap chinese tubes, to the point of having to resloder them myself) , similar mechanical/vibration considerations as above
    3) weak tube construction, some internal part worked loose by vibration and grid lost bias, either because it got internally open or it shorted something inside.
    4) what Enzo says, which happens all the time: some part fails at random , you were using a red T shirt, and think it failed because you were wearing a red t shirt.
    A "ridiculous" example but which I hope conveys the idea that many times coincidence does not mean causality.
    Supporting Member
    Staffordshire UK
    3,767
    Received: 514/1
    Given: 468/2
    18
    ' The average cathode current rose slightly over idle when playing but nothing major'
    Unless it was just at low gain setting, that seems strange.
    What happens to the cathode currents at full power (compared to static conditions)? With and without the octaver?
    Old Timer
    Chill-Ville, VA
    3,169
    Received: 672/6
    Given: 1,300/9
    18
    The shine in the top of the tube is the getter, for trapping gases that are released over the normal life of the tube. That you now have something similar on the side of the tube makes me think one of your grids got vaporized! I've seen tubes redplate, but never turn orange... that's pretty darn hot if the plates were orange! Was there any increase in hum before the tube blew?
    About the bias - don't THINK "unlikely because it's new & high quality." KNOW for sure! Even if the bias is reaching the solder tab, are you sure it's making it to the tube pin? As the tube is pretty well dead, maybe play "Dissect-A-Tube?" And, dim bulb tester! No sense in torching costly power tubes. Can you post a pic of the dead tube? I'm just curious.
    Justin
  12. #12
    Jul 2012
    The 26th state
    589
    Given: 1/0
    8
    Quote Originally Posted by GregS View Post
    I wasn't referring to you Greg, sorry if you took it that way.
    --Jim
  13. #13
    Oct 2007
    11,753
    Received: 1,881/23
    Given: 1,463/35
    27
    To see it from another point of view (although it leads to a similar conclusion) , post mortem autopsy or not, there's something we already know: the tube was glowing orange.
    As justin says, it is a lot of heat ... which in due time means a lot of power is being dissipated.
    And power is V * I .
    Since voltage is predefined by the PSU, only variable left is intensity.
    Tube current (at a given plate voltage) depends straight on grid voltage so everything points to either gross lack of bias or destruction of grid function (internal shorting, wire breaking, loss of wire to pin contact, etc.)
    I fail to find other plausible explanations.
    That the tube afterwards does not pass much current, if any at all, may come from destruction of internal structures ...... but while glowing orange it was passing a lot.
  14. #14
    Sep 2008
    350
    Received: 1/0
    Given: 1/0
    12
    Ok. Thanks for making that clear.
    Greg
  15. #15
    Sep 2008
    350
    Received: 1/0
    Given: 1/0
    12
    1) There definitely was more vibration happening than normal so that is a possibility.
    2) Possible. I'd have to take the base apart to confirm that. From what I can see inside the glass the connections are still intact there.
    3) I'd say likely. For the record the tubes are Electro Harmonix 6550's. I'm not sure where they're made.
    4) Most likely random although extra mechanical stress from vibration might have contributed. I concluded from my simple test that the power tubes are not dissipating any more with the octave on than with it off. That was my original suspicion.
    Greg
  16. #16
    Sep 2008
    350
    Received: 1/0
    Given: 1/0
    12
    Are you referring to the peak signal current? For sure that would be way higher than the idle current. The way I understand how the digital multimeter works is that it averages the readings so you don't see the individual instantaneous readings. It was not at a low gain setting during my test. I would see the current rise by about 8 mA over idle when I plucked a string hard.
    Greg
  17. #17
    Supporting Member
    Dec 2009
    UK
    3,440
    Received: 179/0
    Given: 20/0
    13
    Some octave effects can damage the speaker, though - mainly transistor amps where I've seen this; quite a few sub-octave pedals generate a square wave and in an amp where the speaker is closely matched to the amp's output. Pushing the amp too hard with the sub engaged and turned up pushes a lot more thermal energy into the speaker than a regular bass waveform.
  18. #18
    Sep 2008
    350
    Received: 1/0
    Given: 1/0
    12
    Same with me. This was different and more dramatic than anything I've seen before. Yes, the background buzz noise got louder as the signal level faded. I recognize that symptom which is why I immediately looked in the amp.
    I am sure the bias is making it to the tube pin. Inside the tube I can't be sure. The outer plate structure doesn't look damaged at all on the one side I can still see clearly through. From what I can see of the other side it looks ok too. I can't see right in the middle because of the stuff on the glass.
    I'll do my best with my cell phone.
    Greg
  19. #19
    Old Timer
    Oct 2011
    1,951
    Received: 1/0
    10
    Quote Originally Posted by pdf64 View Post
    This makes sense, if the primary impedance decrease and the tube draw the same current, the tube dissipate a lot more power. You basically change the load line and working outside of the power limit.
    I don't know this particular amp, but from looking at My Marshall, I think people really push the power dissipation of the tubes already. I remember I had a thread here about using my Marshall and a signal generator to get 60Hz to break in the speaker, I ran no more than 30Wrms on a pair of 6L6. I reach down to 50Hz on and off, I blew 2 tubes in 2 hours!!! That's a guitar amp, I did reach below guitar frequency too. I ended up buying an 18V transformer and using a variac to finish the breaking in.
    Ha ha, I've been in the DIY audio forum looking at building an audiophile amp. I learn that DC imbalance between the two half of the push pull really becomes very critical at low frequency. When you use an Octive, you reach into that region, if you have DC imbalance the efficiency goes down, in turn you crank up the amp.....and the tube goes poof!!!!
  20. #20
    Supporting Member
    Staffordshire UK
    3,767
    Received: 514/1
    Given: 468/2
    18
    OK, sorry I'm more used to measuring things with a sine wave as the signal, rather than an instrument.
    With the meter on dc, what happens to the cathode current when there's a continuous full power sine wave?
  21. #21
    Oct 2007
    11,753
    Received: 1,881/23
    Given: 1,463/35
    27
    ^^^^^^^ I remember that.
    I think I commented that using an amp, and a tube one at that, to get important and continuous power at 50/60 Hz was, at least, inefficient , let alone making the poor guitar amp work very hard (a transistor amp would have suffered much less) and to boot, any cheap mains transformer can do that (and nothing else) all day long with no sweat
    EDIT: simulpost, I was answering alan
  22. #22
    Sep 2008
    350
    Received: 1/0
    Given: 1/0
    12
    One thing to note is that nothing around the tube heated up much which indicates that it occurred very suddenly rather than a gradual ramp up of current. Probably a sudden catastrophic failure.
    One other thing I haven't mentioned is that the grid leak resistors I used are a little high for a 6550 at 220K. With the lower value grid leaks the output of the phase inverter was getting loaded down to much and the amp wasn't making full power.
    Greg
  1. No load connected - damage to amp?
    By GregS in forum Theory & Design
    Last Post: 10-02-2010, 12:10 AM
  2. Will I damage my keyboard amp?
    By B_K in forum Other Amps
    Last Post: 06-29-2010, 10:55 AM
  3. Miscellaneous Question About Amp Damage
    By Mbwa in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-29-2009, 11:52 AM
  4. Will bass damage a valve amp?
    By willvdw in forum Tubes (Valves)
    Last Post: 08-30-2007, 01:53 AM
  5. Did i damage my amp?
    By slacker190 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-03-2007, 03:22 AM
