Radial caps in fender amps
  • Radial caps in fender amps
    Hi.
    I have a couple of Fender amps here. Some with the old Capacitor Can section, and some like the newer Deluxe's, with the caps mounted to the PCB.
    I have a an ample amount of Radial type capacitors with the proper values. It's difficult to get axial's around here.
    Can these be made to work? Are there any tricks I should know of??
    Super secret tricks:
    Get the polarity right and mount them so they won't be rattled around. Some good non-corrosive-curing silicon RTV (GE Silicone II qualifies) will help with this last.
      Also, if the leads have to be extended outwards, give them a good knee kink to help absorb any shock and/ or vibration.
        Jazz, a bit more explanation needed for my imagination. Is it ok to lay one leg along the capacitor body towards the other side to emulate an axial capacitor orientation?
          It's o/k to wrap the leads around the body.
          I wouldn't let it touch the can.
          Small diameter heat shrink tubing will do.
          Then again, this guy got away with it.
            I think that I would try and keep the hot end of the power supply caps as short as possible and extend the grounded leg.
              Gluing the cap down to the board is a good idea. Another trick is to use a tiewrap. If you don't want to drill holes in the board, use the tiewrap to hold the extended lead to the body of the cap. If you can find some heat shrink that is big enough, you can use that to hold the lead to the can.
