Results 1 to 6 of 6
Thread: Crest CA18 Preamp issue
    Supporting Member rf7's Avatar
    Sep 2007
    586
    Received: 1/0
    I have a Crest CA18 on the bench that the top half of the waveform folds early on one channel. I swapped modules and determined that the issue lies in the preamp PCB. I checked all of the semiconductors and the resistors, and they all measured fine. The rails all measure fine. The PCB is not accessible, so I can't get a scope probe in there. Any ideas for how to chase this down?
    crest-ca18-power-amplifier-circuit-diagram.pdf
    Dec 2008
    Wernersville, PA
    12,362
    Received: 111/1
    Given: 31/0
    On a hunch I would blame it on the limit circuit.
    Specifically, the NE5517 ic.
    Sep 2007
    586
    Received: 1/0
    OK, I'll check that out.
    Sep 2007
    586
    Received: 1/0
    That was it! Thanks Jazz!
    Dec 2008
    Wernersville, PA
    12,362
    Received: 111/1
    Given: 31/0
    O/k, can I have half of the hair back that I pulled out on the one that had the same issue?
    Sep 2007
    586
    Received: 1/0
    Sorry, I can't help you with that. It is a tough amp to troubleshoot, because you can't really probe inside those amp modules when they're installed in the chassis. Thanks so much for the help, I really appreciate it!
  1. Crest CC2800 Help!
    By pontiacpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-21-2017, 04:17 PM
  2. Crest audio CC1800
    By paleeman in forum Schematic Requests
    Last Post: 06-03-2017, 09:47 PM
  3. Sansui Model 2000 Preamp Issue
    By stereomonostereo in forum Other Amps
    Last Post: 10-19-2014, 06:17 AM
  4. B15 Preamp issue
    By hylaphone in forum Debugging Your Build
    Last Post: 12-30-2013, 11:14 PM
  5. CA18 Chines Built Amp. distortion in one channel
    By master5string in forum Other Amps
    Last Post: 02-02-2012, 02:46 AM
