Marshall encoder
  • Marshall encoder
    I cant find one anywhere ?
    encoder for a Marshall JMP-1 preamp
    M-POTM-00005
    Bourns makes one but the shaft is different , etc....
    any sources ?
    Is this the Bourns one you found or might this be a different one that will work?
    ECW1J-C36-CC0024L Bourns | Mouser
      Mr Dude - the mouser one has too short of a shaft , and the marshall knob wont fit ( so ive read ). if it was mine id use it, but the owner wants the exact replacement.
        Where did you read that? I read on Marshall forum that it is the correct part?
        Is the old one intact? Measure the shaft. The Bourns part shaft is 1/4" diameter, 1&1/4" long, how much longer could the Marshall part be?
          Is this the part?
          The JMP-1 parts list calls it out as a "PD1A DATA INCREMENT CONTROL"
          Korg Parts Data Increment Control Encoder PD1A | eBay
          Here is another pic: Master Service
            Yes that's it, as far as I know, the Bourns pot just solders in to that tiny board.
              thats the one Mr jazz ! thanks !
              G-one , i dont recall where i read that , but i brought that info up to the owner and he didnt want the $5 one. (id use it )
