Hi all,
I'm embarking on a new project. It'll be a 2 channel affair (high gain/fender clean) into a pair of KT88s. The problem is I've never used KT88s before, let alone designed a power supply that will power it.
I read a post on another forum that said essentially a typical Marshall style power supply getting somewhere near 500v is ok, as long as there are 200+ ma current as well. I've tried to simulate this in Duncan's PSU Designer, but get -0v warnings. I'm not sure I'm setting it up properly. The Pwr Supply and Power Stage designs are kind of a mashup of the Naylor Superdrive 60 and the Deliverance 60 (LTPI as per the Naylor, but with P/P KT88 values from the Deli).
Anyway, does this look like it'll work? I'm specifically looking at are the PSU values look ok, and do the PI/PA values look ok for the KT88s?
Any info would be most appreciated.
Thanks!
Output Stage:
Power Supply:
Preamp:
PS Sim (as close as I could get without generating warnings or errors):
Thanks!
Output Stage:
Power Supply:
Preamp:
