Results 1 to 19 of 19
Thread: SVT-CL - Ticking
    Senior Member TimmyP1955's Avatar
    Mar 2007
    Indianapolis
    353
    Received: 5/0
    Given: 2/0
    SVT-CL - Ticking
    About every 1/2 second, varies a bit with temperature. Usually when one of these ticks, it's because the tube board plate is not making electrical contact with the chassis. This one is OK in that regard. And I've checked all of the chassis grounds that I can find. The ticking is coming from the speaker out, preamp out, and slave out. So far the scope hasn't shown me anything. Any ideas before I dive back in?
    Jan 2011
    NorCal
    276
    Received: 7/0
    Given: 15/0
    If it's an intermittent connection (cold/cracked joint, broken wire, etc.) a chopstick is a good troubleshooting tool. Put pressure on various places to see if you can change its behavior.
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    The noise being at the Preamp Out pretty well indicates that it is at that jack or before it.
    The preamp.
    I would start by checking the power supplies.
    See if it shows up on any one (or all) rail.
    If it is not a supply problem then start at the Pre Out jack & work your way back to the input.
    You have to find out if it is global or does it start somewhere.
    Feb 2010
    10,185
    Received: 329/1
    Given: 645/0
    Also, have you ruled out all the tubes as possible sources of the noise? I seem to recall some mention of certain preamp tubes causing "geiger counter" noises.
    Mar 2007
    Indianapolis
    353
    Received: 5/0
    Given: 2/0
    It's not the preamp - if I disconnect the PSU lines or the ribbon, the ticking stays the same or gets louder (depending on which I disconnect). I also swapped in a different preamp just to be sure. Sigh.
    Mar 2007
    Indianapolis
    353
    Received: 5/0
    Given: 2/0
    Solved!
    Two of the tube retainers were not continuous to ground. I fixed that and all seems well.
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    You lost me on that one,
    What does tube retainers have to with it?
    Other than the fact that you may want to consider cleaning (DeOxit) & retensioning , at least, those two sockets, if not all of them?
    Senior Member audiopete's Avatar
    Apr 2010
    North of Toronto
    217
    Is there a chance this is arcing in a failing power tube or output transformer primary? Bad socket?
    Apr 2010
    North of Toronto
    217
    Quote Originally Posted by xtian View Post
    You can also try a can of FreezeIt. Watch out don't hit any hot tubes or components, just solder joints and component leads.
    Apr 2010
    Burbank, CA
    803
    Received: 81/0
    Given: 217/0
    Tube Retainers?
    Like Jazz P Bass, I too don't follow this one. Is this the recent style SVT-CL like this:
Name:	Bias Set-up-2.jpg
ID:	31869 Click image for larger version.
Name:	Silicon Rubber Tubing-1.jpg
    I've never come across any with this kind of repetitive ticking on these amps, and only the power tubes have retainers, none of the preamp / driver tubes do. Or is this an older SVT Classic where there are a bunch of preamp tubes, all having the spring-loaded shields?
    And the tube sockets on the recent generation boards....the PCB mounting standoffs aren't grounded that I can recall
Name:	V1 Pwr Tube Solder Joints.jpg
    I do come across fractures sometimes on this board, as can be seen on that tube socket. But never heard the ticking you describe. Add another gremlin to the files. Interesting.
    Supporting Member Alex R's Avatar
    Mar 2007
    UK
    1,309
    Received: 1/0
    Given: 6/0
    if it's irregular then it could be a transformer winding. Heater windings can do it, very hard to trace. Tapping the transformer windings should produce motion sensitive noise if it is that.
  12. #12
    Mar 2007
    Indianapolis
    353
    Received: 5/0
    Given: 2/0
    When we bought a number of SCV-CLs before my time here (10.5 yrs), a number of them ticked like this. The problem per Ampeg was (as mentioned in my OP) that the center plate was insulated from the chassis by the paint (which apparently caused a charge/discharge). We scraped the paint at all the mounting screw locations and the problem was solved on every amp.
    This problem would seem to be an extension of that - the tube retainer was insulated from the center plate. Same charge/discharge.
  13. #13
    Apr 2010
    Burbank, CA
    803
    Received: 81/0
    Given: 217/0
    That's very interesting, and one that I'd never have suspected as a cause.
    I did have one SVT-CL some time back have random noises, static & clicking.....probably the same ticking noise, but it came in spurts, and not cyclic. I had narrowed it down to the power amp section, and finally the sextet of power tubes, and swapped them out, ending the problem. Earlier in the servicing of that amp, I had done a full tear-down to get at the solder fractures on the main PCB, tightened up the XFMR mtg screws while that board was lifted up, and had the power tube PCB removed for replacing the screen resistors. I had fully reassembled the amp, with the hold-down clamps back into place before I ended up swapping out the sextet of power tubes.
    In my previous post, I had mentioned not recall seeing the mounting hardware of the octal sockets being grounded. I'm just finishing up servicing an SVT-VR, and those socket's flanges ARE TIED IN TO Pin 1, which on some 6550's & KT-88's that connects to the metal base of the tube, while on others, it's no connection. I did see in JJ/Tesla's KT-88 data sheet Pin 1 could be tied to Grid 3 (suppressor grid), though that's normally tied to the cathode. The chassis of the SVT-VR has masked off 3/4" circles around the cover plate mounting screw locations, with the back of the cover plate having 1/2" circles around the thru-holes for mounting the plate to the chassis, so there IS ground continuity on that plate, and all the way to the metal base of the power tubes, as can be seen in the photos below. The wide masked off area on the back of the top plate picks up the metal flange of the power tube socket, completing the ground path of Pin 1 to the plate and on to the chassis.
Name:	SVT-VR Power Tube PCB-2.jpg
ID:	31911 Click image for larger version.
Name:	SVT-VR Power Tube PCB-3.jpg
ID:	31912 Click image for larger version.
Name:	SVT-VR Power Tube Cover Plate-1.jpg
ID:	31913 Click image for larger version.
Name:	SVT-VR Power Tube Cover Plate Removed-1.jpg
    During the last bit of service on this SVT-VR, having found one of the power tubes had an open heater, and after de-soldering and re-soldering Pins 2 & 7 with no success, I was forced to select thru that sextet of 6550 Sovtek tubes for a matching tube to balance out the sextet (measuring across the 5 ohm plate resistor thru my insulated top plate made for servicing the SVT-VR's). I was apprehensive about selecting a tube out of that batch that was the noise source before, but it's dead quiet.
    I only had four photos of the SVT-CL power tube PCB, and those being close-ups of the tube sockets to show the solder fractures in my records. I didn't see Pin 1 being connected to the hex spacer as I see on the SVT-VR PCB assy. I don't recall seeing any attempt on the SVT-CL chassis nor power tube cover plate for insuring ground continuity.
    It's only by chance, in tightening down mounting screws that you'll radius the head of the screw thru the painted surface of the plate to actually ground that plate to the chassis (by way of the pressed-in pem nuts receiving the machine screws). Paint does make a good insulator. We do have two very recent SVT-CL's that have a later generation power tube PCB, where they changed from the double-row ribbon connector to a single-row style. I'll have to have a look at that amp to see if they ended up grounding the power tubes/plate/PCB as they did on the SVT-VR.
    That is one for the books for sure.
  14. #14
    Mar 2007
    Indianapolis
    353
    Received: 5/0
    Given: 2/0
    This has the CL style coil spring hold-down retainers, as opposed to the base clamps. Grounding indeed would appear to be by happenstance - something has to cut through the paint someplace to connect the retainer to the plate and the plate to the chassis. (I've never payed attention to the status of Pin1 on any of these things.)
  15. #15
    Junior Member
    Sep 2008
    13
    Old thread, but for info purposes. Have an Ampeg svt Classic at workbench and pin 1 of 6550 tubes is not connected to the hex spacer. Double-row ribbon connector on this amp
  16. #16
    Apr 2010
    Burbank, CA
    803
    Received: 81/0
    Given: 217/0
    Please begin a new thread and be a bit more specific with the problem you're having. BTW, Pin 1 of the 6550 power tubes are NOT connected to any hex spacers, on the power tube PCB. This 'thread' was involved with a 'ticking' sound from an SVT.
  17. #17
    Junior Member
    Sep 2008
    13
    Quote Originally Posted by nevetslab View Post
    My post was for info purposes about the 6550 pin 1 being connected or not to chassis via hex spacers in CL vs VR models. I'm not talking about any problem, just confirming ( if any doubt ) that pin 1 is not connected in CLassic model
  18. #18
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,627
    Received: 546/1
    Hi Joss, I am old and probably confused. I am unclear on your meaning. By connected via hex spacer, are you telling us pin 1 is not grounded, and a hex spacer is what connects ground on the board to the chassis? Do you expect pin 1 to be grounded?
    Where do the pin 1 traces on the board go?
  19. #19
    Junior Member
    Sep 2008
    13
    Hi Enzo. The hex spacers are the mounting hardware between pcb and octal sockets. They are connected to pin 1 of power tubes in VR model and chassis if all the stuff is properly mounted. In the CL model the pin 1 of power tubes is not connected to anywhere ( no trace there ). My post was just to make 100℅ clear what i'm saying about pin 1 on CL model, but my english seems to sucks more than i thought. Sorry guys ..
  1. SVT-CL misbehaving
    By Prairie Dawg in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-20-2018, 12:46 AM
  2. Ampeg SVT CL
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-05-2016, 09:40 PM
  3. Ampeg SVT CL
    Last Post: 08-09-2014, 12:10 AM
  4. Ampeg SVT CL
    Last Post: 03-26-2013, 11:36 AM
  5. Ampeg SVT CL
    Last Post: 02-05-2013, 07:24 PM
