I know Mojo and FX offer A5 or (blech) ceramic firebird magnets, but I'm far more partial to A4 for any kind of HB pickup. Am I chasing unicorns, or is it possible to get something in that size in A4. Heck, I'd even like to tinker with A3 for that matter.
Does anyone offer Firebird sized magnets in Alnico 4 or Al 3?
I try to keep up with magnet pice lists.
Don't know of any that size in A2, A3 or A4.
For prototypes, I've ground some regular bar magnets off to 2.05".
Let them stick out the bottom of the bobbins, and shim up the bobbins.
Another option is to use a .5x2.5 on the bottom and use steel slug bars in the bobbins.
Both will work.
TLast edited by big_teee; 12-12-2014, 04:40 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
I'm sure there are proper ways to do it?
I just wanted a couple, and I ground them off.
It took a while, and I tried to not let them get too hot.
If you need lots of them?
Shea at Magnetichold will get you whatever you want.
He has a minimum $40 order.
shea@magneticholdcompany.com
http://music-electronics-forum.com/a...price-list.pdf"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
We've had discussions here about cutting various magnets which you can look up. Tile saws work wonders with ceramic magnets. Alnico might do OK with a wet tile saw but the diamond grit has a tendency to become absorbed into ferrous metals if the temperature is allowed to get much above the boiling point. Best bet is to just order a bunch from whoever is willing to work with you. Figure a month minimum for custom orders from Chinese sources. You may find it cheaper to order in larger quantities from the Chinese foundries than to order a few samples from a reseller like Magnetic hold or Allstar. You have to factor in shipping via air courier which is often as much as the magnets.
It might be worth checking with the US foundries just to get a price. Say you need 20 magnets but end up ordering 250 you can always put them up for sale around here.
Originally posted by Bryan Jeppson View PostPut in an order of 50 from Shea. Thanks for the suggestion Tee.
Shea has been good to order special Types and sizes.
GL,
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
