Fender Hot Rod Deluxe : instability when in More Drive mode
  • Fender Hot Rod Deluxe : instability when in More Drive mode
    Hi,
    A friend of mine gave me this Fender Hot Rod Deluxe to be repaired.
    Here's the schematic and layout :
    http://support.fender.com/schematics..._schematic.pdf
    The problem is : when in more drive mode, there are some oscillations happening.
    Here are the tests and reasonings I've done so far :
    - No oscillations happen in clean or drive mode, so I guess those are caused by the very high gain of the more drive mode (gain increased by bypassing both V2 cathode resistor)
    - I switched the preamp tubes, oscillations still happen with erevy tube I put into the amp
    - The oscillations are not affected by the drive gain pot or the master pot. The only control that affect the oscillations is the treble control. When this is at a very low value, the oscillations are reduced. I guess this is because less "high" frequencies come to V2 and excite the oscillating frequency.
    - I ran the amp without the power tubes to get rid of any "acoustic" coupling : no results. I even removed the phase splitting tube (12AX7) without any result.
    - I shorted R23 and R24 to get rid of the jfet switches, nothing changed.
    - When I touch the middle of ribbon cable of V2 (it connects G1-C1-A1 and G2-C2-A2 to the main board), I get some squealing. The wires in the middle of the ribbon cable connect A2 and C1. Seems to me that the circuit is instable and that the "link" made when I touch the ribbon cable is enouth to get the circuit into frank oscillations.
    I guess I could get rid of those oscillations reducing the gain of V2B by lowering the plate resistor, or adding a resistor in series with the cathode bypass capacitor (the one that are "activated" in "more drive" position). I could also put some low value capacitor (a few pF) in parallel with V2's plate resistor to lower the HF gain, but those mods would affect the amp's tone for sure.
    I also doubt that Fender let an oscilating amp go through their test procedures, so some part must have gone wrong !
    Here is a sound file illustrating the problem :
    https://drive.google.com/file/d/0B6K...ew?usp=sharing (please let me know if the link doesn't work)
    This has been recorded through the "preamp out", without the output tubes, so no sound at all on the speaker. There is no speaker simulator or LPF, so the distortion sounds harsh as expected
    At the beginning, the guitar's volume pot is turned all the way down. We can already hear some "phantom" oscillation behind the hiss. Then I played some notes where you can hear the oscillation ringing, especially during the sustain of the notes. Then I touched the V2 ribbon cable, and you can hear those frank squealings.
    Has anyone any idea of what could have gone wrong in this amp to cause such instability ?
    Thanx in advance.
    Best regards.
    Eric
    Perhaps there is an open somewhere in the path that connects C3 250pF cap to gnd when in drive. Candidates are relay section K1B pin 9, solder joints or C3 itself. Check for continuity to ground when in drive.
      On the pcb, over at the input jacks, is a big electrolytic capacitor marked C36.
      Hook up a DMM to the two leads.
      Set your meter to read Volts/ac & measure the 'ripple' on the cap.
      10 to 1 you will find a high ripple reading.
      If so, that is your likely culprit.
        yes the big filter caps would also be my prime suspect on these.
          Absolutely the filter caps.I've repaired at least a dozen of these newer Fenders,Hot Rods,Devilles,Blues Jrs etc and some reissues,all had similar oscillations,all repaired with a re-cap.Those Illinois caps suck.Use good quality Spragues or F&T's.
            If you have a scope (a DMM will suffice) & you get on the capacitor leads (C36) while set up for the issue at hand (more drive mode), when you strike a note, the note will be impressed on the positive lead of the cap.
            With a good cap, the signal on the lead will be very quickly dampened & then it will be gone.
            With a faulty cap (C36) the signal will continue to ride on that power supply node.
            This is why that particular capacitors function is refered to as a 'decoupling capacitor'.
            It is there to decouple any signal that is impressed on that power supply node by the action of the preamp tube plates, on that node.
              If the typical filter cap issues don't get you anywhere, the actual placement of the ribbon cables can be pretty finicky. Being bent in non-stock positions can cause weird problems, and rear panel shielding/grounding can also.
                That, and I've seen shielded cable bypassing the ribbon cable to V1 input grids pin 2 & 7.
                Try to use the quietest tube you have for v1.
                Also reflow the tube socket PC board connections and any bad looking ones on the main board like pots and jacks, dropping resistors etc.
                  !! This is an important factoid to remember with Fender amps. I've seen head-scratching oscillation issues that vanish when the rear panel is put back in place.
                  http://amps.monkeymatic.com
                    Especially with ribbon cables up against the rear panel.
                      Hi,
                      Thanx a lot for your great answers !
                      I checked the PSU caps (put another 22uF in // with the existing ones) and C3 and its associated relay, but everything looks OK, no improvement with the cap in //.
                      As I have no earth connected on the living room where I temporarily have my bench, pulled a cable from the bathroom where I have an earth connection and... the oscillations disapeared !
                      I guess my friend tested it without earth either...
                      BTW, any idea of how to get rid of that behaviour when plugged without a proper earth connection ? I know this shouldn't happen, but I have even seen it in some "professional" clubs...
                      Anyway, I'll change the PSU caps for better ones, just in order not have this amp on my bench too soon
                      Thanx again for your contributions, every clue can turn into a solution the next time !
                      Best regards.
                      Eric
                        Does Post #9 help?
                        The chassis should not be carrying any current, so this makes no sense to me.
                          Does Post #9 help?
                          Well putting back the cover wasn't necessary to stop the oscillations....
                          The audio ground does connect to the chassis, and thus to the earth when present. How this has an influence on the oscillations... I don't know
                            Problem is, many time only those crap IC caps will fit on the board. Spragues won't fit and F&T probably won't either. Stupid Fender.....
                              Check both ends of the ribbon cable for broken conductors. Even though the wire is still soldered though a hole in the PC board, they can break right where the insulation starts. With the power off, just poke each wire at the ribbon cable and make sure it isn't broken before it goes into the insulation at both ends.
