Page 3 of 3 FirstFirst 123
Results 71 to 73 of 73
Thread: Orange drops or Mallory 150s in 5E3 build?
  1. #71
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,435
    Received: 3,071/5
    Given: 3,709/0
    32
    I've bought both Teflon and silicone jacket wire "by the foot" for a couple of projects. Fun to work with. Nice to have no fear of shrink or fouling a lead with the tip of the iron. But so expensive!!! I decided that I'd be better off improving my soldering skills and paying better attention.
    I don't think even major amp brands that use PVC use plain PVC. The first lead wire I ever bought (some twenty five years ago?) was plain PVC and it was awful. I used it for two short mod projects and then replaced it.
    Did I mention irradiated PVC is damn fine stuff and cheap? Don't let the interwebs sell you on Teflon lead wire. It's not necessary in guitar amps.
    1 Not allowed! Not allowed!
  2. #72
    May 2007
    pacific north west
    16,435
    Received: 3,071/5
    Given: 3,709/0
    32
    Yes, rules are made to be broken. For example I might melt a little fresh solder into a joint first to "wet" it. Then I can solder properly and the wet joint will take solder more easily.
    Sometimes, if a component is old and I'm in a hurry, rather than buff or clean the component lead I'll just melt a little flux core onto it. If it flows I know I'm good to go.
  3. #73
    Cornelius, Oregon
    1,426
    Received: 116/0
    Given: 212/2
    16
    You will find that your soldering will be 100% better with a temperature controlled soldering station rather than the 40 watt iron or 60 watt iron or whatever. Leaded solder is also much easier to work with. I usually pre-tin my tip with a little blob of solder then put that on the joint to help heat transfer quickly. If you can get a good mechanical joint before soldering that really helps too. Some of the old military tube equipment would have to be full power tested with no solder or very little solder in the unit, then after passing that test, they would put solder in to hold the parts in place. You can really only do that with terminal strips and turrets with the wires wrapped around them. If you try it with eyelets it doesn't work nearly as well.
    Greg
    4 Not allowed! Not allowed!
  1. first 5E3 build
    By Doc Stitches in forum 5 E 3
    Last Post: 02-23-2012, 03:38 AM
  2. Help with 5E3 build...
    By mnexsen in forum 5 E 3
    Last Post: 08-09-2010, 02:24 AM
  3. Replies: 32
    Last Post: 03-01-2009, 02:59 AM
  4. My 5e3 build
    By dobsont in forum Tweed Builders
    Last Post: 03-03-2008, 07:25 PM
  5. Want to build an Orange head
    By elvisjer in forum Theory & Design
    Last Post: 08-21-2006, 11:03 AM
