Results 1 to 2 of 2
Thread: Fender Super 210 Red Knob - Channel Switching Problem
    New Member
    Feb 2014
    3
    0
    Recently picked up a Fender Super 210 (Red knob, late 80's/early 90's). The clean channel (vol 1) sounds and operates fine but when switched to the drive channel (vol 2) the gain control has no effect, yet the clean volume and the drive volume both function at the same time. I does get loud but does does not produce much overdrive.
    After studying the schematic and reading of similar problems in forums I decided to replace the three opto-isolators involved in the (rather complicated) switching circuit - no change. Also, I can see that someone has been in there and maybe done some repair or mod, so that might complicate things. Is it really even a switching problem? So, I was wondering if I post the schematic, would anyone have a suggestion for what to try next?
    Thanks!
    Fender Super112 Schematic.pdf
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,433
    Received: 2,519/7
    57
    The optocouplers turn on and off by lighting an LED inside, whwich shines on a photoresistor. Don't just replace them out of hope, test them. Use your volt meter to see if the LEDs are passing current or not when they should. You can also usually test the photocell part for changing resistance.
  1. Bias and channel switching supply on Fender red knob PT replacement
    By Ptron in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-08-2013, 08:45 AM
  2. Fender Champ 12 red-knob channel switching problem
    By Mr Johnny Birchwood in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-08-2013, 09:31 PM
  3. Anyone work on a Fender red knob Super 60?
    By Prairie Dawg in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-14-2013, 11:05 PM
  4. Fender Super 60 Red Knob Low power and Hums
    By jcollins in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-23-2012, 02:28 AM
  5. Fender Super 210 - Red knob Vibrolux
    By Chippsta in forum Vintage Amps
    Last Post: 03-21-2007, 03:51 AM
Tags for this Thread
