odd turn off noise - Fender Princeton Chorus - links to Youtube
Originally posted by Jazz P Bass View PostIt sounds like the power supply winding down.
Possibly a bad power supply ripple filter capacitor.
You can check the ripple of each supply with a meter set to read volts/ac.
That's normal.
You do not have a problem.
Many amps do that, including many respected Gallien Krueger.
Originally posted by Jazz P Bass View PostWell, the audio shows a click (switch action) & a dropping bzzzz.
I have seen that bzzzz caused by failing power supply caps.
Usually just one rail.
Can't hurt to test the supply.
Originally posted by Kenrod View PostIt may be common, but i find it hard to believe it's normal.
Or if it is doing it with nothing plugged in to the amp input, please let us know that.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I haven't gotten into this one yet(my sons spare amp) as I've been tinkering on other amps, but I did notice this. The turn off noise is louder with something inserted in the input jack versus nothing inserted. It still there with nothing inserted, just only about as half as loud.
Originally posted by Kenrod View PostI haven't gotten into this one yet(my sons spare amp) as I've been tinkering on other amps, but I did notice this. The turn off noise is louder with something inserted in the input jack versus nothing inserted. It still there with nothing inserted, just only about as half as loud.
