Page 1 of 2 12 LastLast
Results 1 to 35 of 36
Thread: Kustom IV Bass Head Schematics?
    Supporting Member Corona Blue's Avatar
    Morro Bay, California
    107
    Question Kustom IV Bass Head Schematics?
    Greetings all!
    A fellow musician in my local area brought me a Kustom IV Bass head and cabinet he recently bought.
    The amp sounded very nice, quiet and clean, with a nice sounding tone stack.
    But after the amp warms up, it gets the fizzies real bad. Makes a constant hissing.
    I opened it up and it is a beautifully built amp! Date codes on the pots indicate a vintage of '77 or so. Visually, there is no evidence of any trouble. No hot discolored areas on the boards, no over-heated resistors, no swollen caps. I kind of wish there was some kind of clue, but nothing!
    I have looked high and low for the schematics and/or service manual for one of these. They must be somewhat rare because I have found nothing on this particular Kustom model. This is not a "tuck and roll" era Kustom.
    Anyone here have any experience with these? Or maybe some documentation???
    Thanks in advance,
    Allen
    [Edit] I tried to I.D. the various circuit board numbers in this amp. All the numbers are printed on their under side and difficult to read with them mounted in the amp. The pre-amp boards look like they can easily enough come out for service. But the power section is mounted on the rear chassis wall and it does not appear like it will be easy to remove. Best I can see with a magnifier, here are what appear to be the board numbers:
    Upper Pre: 009 5290 00
    Lower Pre: 009 5277 00
    Power: 003 5380 00 (or possibly 009 5388 00... difficult to see clearly)
    Member BasicBassVI's Avatar
    Jan 2015
    Peoria, IL
    22
    If there are any socketed IC's, remove them, clean the pins, and re-seat them. Doing that helped quite a lot in my CV bass head of the same vintage.
    107
    Thanks Basic. I will double check. I noted that the preamp boards use 4558 DIPs but they were soldered fast to the board.
    Both preamp channels and the power board are full of carbon composite resistors. The sound it is making sounds a lot like when a tube amp has a noisy resistor. Carbon composite resisitors can pick up moisture from the air and cause this sort of thing.
    The circuit DOES use socketed connectors to join up the various boards... hmmmm... that seems like a good place to start.
    (I will try to post a couple of pics of this monster).
    107
    Here are some pics of the unit. It weighs in at just about 50 lbs!!
    Fully sealed and shielded chassis...
    Preamp section... this is a "4-holer" amp. Two channels, each voiced a bit differently and each with high and low inputs...
    Power board mounted to heat-sinks... this board looks like it could be difficult to remove for service...
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    Wow, biggest Kustom that I've ever seen. My files don't cover the later Tolex amps, but I have fixed a few of the III heads. I guess that there wasn't a schematic glued to the top plate like the older ones had? They seem to be all based upon the original basic power amp design, only more outputs and smaller ballast resistors. Is this thing bi-amped or single power output?
    The Molex connectors are well known problems in all of these later amps, give them a good cleaning and make sure that the pins are tight.
    What sort of noise is it making?
    107
    Hi Bill!
    It is a single output with a paralleled jack.
    The cabinet that came with the amp is a Kustom 2 x 15 that is loaded with EV15B-SRO's. One of these had an open voice coil. The other sounds great.
    Aside from some scratchy pot noise, the amp sounds fine until it warms up. Then I get the "pink noise" sound, like a noisy resistor in the signal path. The amp still plays, but the noise is up there pretty good.
    I found a guy who had a schematic for the Kustom IV Bass, but the schematic is dated 1974. I think this amp is later. I went ahead and bought it ($20) just to have something. But until I can get the circuit cards clearly identified, I'm not sure how exact that schematic will be. "Close" may be enough for what I need though.
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    Quote Originally Posted by Corona Blue View Post
    Try and isolate it to the preamps or the power amp and then get some freeze spray to find the bad component.
    107
    OK, will try that.
    On the Kustoms that you have worked on, did you ever have occasion to remove the power board and was it a chore to do?
    It looks like to remove this one, I would have to de-solder all the power transistors from the board before the board could swing away.
    Feb 2010
    10,185
    Received: 328/1
    Given: 645/0
    Looks to me like the OP devices are socketed?
    107
    Quote Originally Posted by g-one View Post
    So the device legs plug into those plastic receivers coming through the board?
    I wondered about that.
    That would be great if so!
    I'll get back into the shop this weekend and will look at that closer.
    Thanks g-one.
    Feb 2010
    10,185
    Received: 328/1
    Given: 645/0
    Yes, you can see a pair of screws (no nuts) coming through for each of the OP transistors.
    At that age you will probably want to change out the heatsink compound as it will likely be dried out. Careful with the mica spacers, swaps and alcohol should help clean off the old stuff.
  12. #12
    107
    Yes, those are captive nuts there in the board. I guess that silver rivet in between the transistor screws is what holds the plastic socket to the board.
    I think I remember seeing that there were sil pads under the transisitors rather than mica, but either way I should have a few spares on hand.
    PS g-one, love your sig line!
  13. #13
    Feb 2010
    10,185
    Received: 328/1
    Given: 645/0
    I was trying to figure out what was up with the paint spatters on the chassis floor?. I guess they painted the heatsink without covering up the holes .
    As far as the sig line, I was talking to a friend about how tone will only take you so far, and that was his reply!
  14. #14
    107
    Exclamation UPDATE
    Ok, I had a couple hours to mess with this Kustom yesterday.
    I unplugged and cleaned ALL of the board connectors and cleaned all the pins and receivers and jacks with DeOxit.
    Removed all the pre-amp boards and sprayed and blew out the pots and really worked them over.
    Re-assembled everything, plugged in the speaker cab and powered up the amp.
    I did not have a bass there in the shop, so I just let it run for an hour and worked the pots to see if any gremlins popped up...
    No problems! No excessive heat. I could hear the amp and EQ stages working as I ran the pots. No appreciable hum, no hiss.
    I checked the DC voltage at the big filter caps and read -58 to +58 and 0V at the PT center tap.
    I will get a guitar and try it out this weekend, but so far so good.
    Best,
    Allen
  15. #15
    107
    Exclamation
    UPDATE: Schematics Found!
    Long time since I have revisited this thread, but I wanted to complete it with the schematic of the amp so others can benefit.
    Special thanks to Kustomoholic over at the VintageKustom Forum for these hard-to-find documents.
    Kustom4_Bass
    Thanks to everyone here who chimed in to help!
    Allen
  16. #16
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    And the schematic is where????
  17. #17
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,627
    Received: 546/1
    Jazz, his link opens a schematic for me.
  18. #18
    Feb 2010
    10,185
    Received: 328/1
    Given: 645/0
    I can view it but the download button doesn't work for me.
  19. #19
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    Got it.
    (I do believe that the OP 'editted' the post after my question)
  20. #20
    Feb 2010
    10,185
    Received: 328/1
    Given: 645/0
    Now I was also able to download. The earlier glitch had something to do with the pop up ad page.
  21. #21
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,291
    Received: 354/5
    Given: 356/5
    I could first se and then download it , but the server takes its time to send data, so for a minute or two it looks like it's not working.
    Even before opening it, a classic Enzo Question [tm]: does any control affect the noise?
    That alone splits the amp in a couple functional blocks.
    More later but let's start with something.
  22. #22
    Feb 2010
    10,185
    Received: 328/1
    Given: 645/0
    I believe it was fixed but he is just passing along the schematic. (post #14)
  23. #23
    Junior Member
    Nov 2010
    7
    http://steampoweredradio.com/pdf/kus...lead%20amp.pdf
    The lead (guitar) amp schematic! (Kustom IV)
  24. #24
    Junior Member
    Dec 2017
    9
    I have the schematics for the Kustom IV amp if you are still interested let me know.
  25. #25
    Junior Member
    Nov 2010
    7
    Quote Originally Posted by randysr57 View Post
    Yes I am.
    muziekschuur at gmail dot com
    You have the bass schematic?
  26. #26
    Jun 2006
    California, USA
    3,519
    Received: 95/0
    Given: 43/0
    If Forum readers are interested in seeing the schematic then it would be most useful to just post a copy here within this discussion thread.
    Thanks,
    Tom
  27. #27
    Junior Member
    Dec 2017
    9
    Kustom Bass IV schematic
    Yes I have the bass schematics . I will need time to post them here if you want them..I posted a pic of the Kustom IV bass amp the schematics go to.
    Hopefully the pic attached to the reply
    Quote Originally Posted by Muziekschuur View Post
    Yes I am.
  28. #28
    Feb 2010
    10,185
    Received: 328/1
    Given: 645/0
    These are different from the Kustom 4 bass schematics linked in post #15 ?
  29. #29
    Junior Member
    Dec 2017
    9
    They look like they are different. Part numbers are different too.
  30. #30
    Junior Member
    Dec 2017
    9
    Kustom Bass IV schematics and Specs.
    Here are the Kustom IV Bass amp schematics and specs. I hope this helps out.
  31. #31
    Junior Member
    Dec 2017
    9
    Corona I just recently posted the schematics ...Post number 30
  32. #32
    107
    Hi everyone-
    Wow! "No thread too dead" right? :-)
    Well, Randy's contribution here is interesting.
    I wish we had a real scan of the page that is a jpeg.
    That pic is tough to deal with and the line drawing contrast could be better.
    However, that pic appears to be one of the "missing" pages from the post #15 schematics.
    See the "Addendum to Index" where Kustom explains that the service schematic was (at time of printing) incomplete.
    That pic that Randy sent looks like it might be one of the "Bass IV Interconnect" drawings called out in that original addendum.
    Also, it appears that Randy's pages shows something not found in Kustomoholic's service schems of post #15.
    Namely, the optional Graphic EQ board is shown in Randy's contribution.
    The drawing dates appear to be in the right general window for this amp, but if you're working on one of these, you'll want to match the circuit board reference numbers of the drawings to the board in question there on your bench. There may have been different rev's or even board swaps.
    Thanks Randy!
  33. #33
    Junior Member
    Dec 2017
    9
    Which page?
    Hi everyone-
    Thanks Randy!
    Which page is a jpeg that you need ? I thought it was all PDF's I posted.
  34. #34
    107
    Hi Randy-
    I stand corrected. There are indeed two .pdfs. One of which has a cellphone picture of a schematic page.
    I was just commenting that it would have been nice if that schematic page had been flat-bed scanned rather than photographed.
    But it's not that big of a deal. It was readable enough when I zoomed in on it.
    Thanks again for sharing!
  35. #35
    Junior Member
    Dec 2017
    9
    Corona since I am a stickler for neatness I will scan all the pages on a flat bed and repost . I kind of was in a pinch for time and used my scanner app on my phone. I will try to get them done tomorrow. If you look at my profile pic you will see on the right of the head it has an equalizer. I am the original owner and I have the sales receipt and I believe it said I purchased the amp in 1974..
  1. Schematics for Acoustic 450 bass head needed
    By chris_young in forum Schematic Requests
    Last Post: 10-10-2015, 06:09 PM
  2. 1964 Kustom Model 200 bass amp head schematics
    By kenny73116 in forum Schematic Requests
    Last Post: 01-13-2015, 03:36 AM
  3. Schematics for Trace-Elliot V6 bass head?
    By asfi in forum Schematic Requests
    Last Post: 05-02-2013, 08:39 PM
  4. Peavey Mark IV bass head 400 BH.. Problems...
    By wheatley in forum Music Electronics
    Last Post: 08-22-2011, 03:36 PM
  5. Peavey Mark VIII bass amp head schematics?
    By dongee in forum Schematic Requests
    Last Post: 11-11-2010, 05:06 PM
