Originally posted by kayakerca
View Post
New Winder slowly coming together
Originally posted by Jason Rodgers View PostWord.
Hey Harry, we can use a lampcord to make that pickup...
What type and wire gauge would I use to rewind an old Seymour Duncan Pearly gates plus to get it close to what it was?
Is there any data bases anyone have here that list the wraps per bobbin and magnet to maybe make a SD JB or SD Distortion Humbucker? I'm sure someone here has a list compiled?
Or maybe a good pickup book besides Lollars that I could get cheap that's good? I would like to get Lollars book but I was outsourced in 2013 took a year off then started looking for a job since, time to downgrade as nothing around me in my field...Its a pain in networking when I have an Alcatel background but everyone wants Cisco...Last edited by Slobrain; 02-03-2015, 08:00 PM.
Originally posted by Slobrain View Post[ATTACH=CONFIG]32743[/ATTACH] Hey Harry, we can use a lampcord to make that pickup...
Or maybe a good pickup book besides Lollars that I could get cheap that's good? I would like to get Lollars book but I was outsourced in 2013 took a year off then started looking for a job since, time to downgrade as nothing around me in my field...Its a pain in networking when I have an Alcatel background but everyone wants a Cisco...
Originally posted by Jason Rodgers View PostRight on! That'll do it.
Did you say earlier, where you got your bobbin mount discs?
I superglued them on... They are holding pretty well too.
I have to ask about 2 sided tape to use. I found some at home depot that has some kind of material in it and real sticky or do the folks here use something different?
here is what I found but I think it isn't what everyone else uses.
Roberts Indoor/Outdoor 3 in. x 15 ft. Double-Sided Carpet Tape Roll-50-605-12 - The Home Depot
Carpet tape might be a lot too grabby. I use some double-stick 3M stuff that comes in little strips: it can be wiped with a wet cloth to clean and reactivate the sticky. Find it in the office supply section of your grocery. I've had the same stuff on my platen for all my winds and it's still plenty sticky.
Little tip: turn on your machine and use a Sharpie to draw bullseyes on the discs. Since we're centering bobbins by eye, instead of with registering holes, this helps a lot.
Originally posted by Jason Rodgers View PostCarpet tape might be a lot too grabby. I use some double-stick 3M stuff that comes in little strips: it can be wiped with a wet cloth to clean and reactivate the sticky. Find it in the office supply section of your grocery. I've had the same stuff on my platen for all my winds and it's still plenty sticky.
Cheers
The 3M tape in question is called R100 but that isn't featured prominently in the packaging. The tape is a clear mastic about 1/32" thick. It comes in rectangular sheets or a roll.
Scotch 859: Removable Clear Mounting Squares | OfficeWorld.com
Edit: Now they're calling it 3M Scotch 859.
I should give credit where due: it was Mr. King who pointed me to this tape.
Don't worry too much about where you get your hookup wires. Do you have a Fry's or old-school Radio Shack nearby? Get some 26 or 28 gauge stranded wire in the colors you want for a few bucks per 25 foot role. Got any old USB cables around? I found one with red, green, black, and white wires, foil wrap, and braided shielding. I got my magnet wire from Remington on amazon for about $29, lead wire from Fry's for $12, and the USB cable was free from the IT guy at work who was throwing it out. If you want to go all legit and vintage and stuff, get the real goods: I happen to enjoy going to lengths NOT to buy materials from the usual, proper suppliers.
Originally posted by Jason Rodgers View PostI should give credit where due: it was Mr. King who pointed me to this tape.
I sure would like to find the exact wire that SD uses but I'm sure its not cheap. Back in the late 90s, early 2000s when I was building Soldano SLO 50/ 100 clones I used to get wire from this guy below. Its silver plated Teflon stuff and worked excellent. Three of these I built. The second from the top with the EL34s my buddy built. Did these around 2001 and 2002
Apex Jr.Home Page
Someone on Ampage had pointed me to Steve at Apex and I was glad. I guess I should check the site and see what he has that would work.
BTW, the 3m dual sided stick tapes worked great. Thanks guys.
CheersLast edited by Slobrain; 02-12-2015, 01:55 AM.
For hook up wire on the bobbins, I use this.
http://www.amazon.com/Ul1007-1569-St...07+28+awg+wire
In white, black, red, and green.
For lead wire for the pickups, I use 2 wire with shield, and 4 wire with shield.
2-Conductor Shielded Guitar Pickup Wire
4-Conductor Shielded 28 Gauge Guitar Pickup Wire
If you plan on selling any pickups, you might as well get geared up with the right stuff!
It costs a little more, but doesn't take that much of it.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
