CF DC coupled question
Originally posted by Tahoebrian5 View PostCan someone shed some light on the following CF configuration. Most schematics I've seen don't have a voltage divider between the last stage and the CF. What would be the purpose of the divider and the capacitor shown here (top circuit path)?“If you have integrity, nothing else matters. If you don't have integrity, nothing else matters.”
-Alan K. Simpson, U.S. Senator, Wyoming, 1979-97
Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
https://sites.google.com/site/stringsandfrets/
One reason for the divider might be to increase the availabe signal amplitude (headroom). The cathode follower in the traditional configuration steals about 100V of headroom from the driving stage because grid current starts to flow in the follower if the plate to cathode voltage gets too low. The fix for this is to hot bias the driving stage to get some headroom back.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
It looks like the cap is added in there so that the AC and DC can have independent voltage dividers that result in different amounts of respective attenuation. That .22uF cap with those resistors calculates out to about a 1Hz break frequency. It is not there for "tone shaping"; it is essentially the AC signal ground. The DC voltage is reduced by about 50% but the AC voltage is reduced by just over 70%.
I didn't know some of the stuff the guys previously mentioned. Putting it all together, it seems like a pretty clever solution to some typical issues that allows independent flexibility of the AC & DC portions of the circuit. Something I'll have to try out in the future.
I'm getting the same 1hz using the filter formula and plugging in the 2 resistors. Weird thing is I took it out of the circuit and it seemed like it was brighter. Is there some others hidden impedance that needs to be accounted for in the formula? Or maybe the miller capacitance of the cf coupled with the 2 resistors changes the freq response?
Intuitively, I would expect it to appear to sound brighter with the cap removed. My guess it that it is related more to our ear's perception (Fletcher-Munson ear sensitivity curves, etc.) than anything. I kind of doubt that a bode plot of the frequency response would have a different shape; the whole thing would just be higher in amplitude.
That being said, you do also have to think about how the signal is affected by the driving impedance / capacitance of the preceding tube, miller capacitance at the grid of the CF and other subtle differences at the grid of the CF tube that can slightly alter the high frequency response as the grid leak resistor value (as seen by the AC signal) is changed. All told, it is probably still pretty subtle and probably difficult to show measured differences that add up to anything appearing significant (again, just intuitively guessing here - please correct me if you have actual experiential knowledge).
Originally posted by loudthud View PostOne reason for the divider might be to increase the availabe signal amplitude (headroom). The cathode follower in the traditional configuration steals about 100V of headroom from the driving stage because grid current starts to flow in the follower if the plate to cathode voltage gets too low. The fix for this is to hot bias the driving stage to get some headroom back.
