View Post
Bias on Ampeg BA115 too low cause occasional random-ish noise?
To clarify, we're talking about this one.Ampeg BA115HP 220 Watt 1x15_ Bass Series Combo Amp _ Musician's Friend.pdfAmpeg BA115HP.pdf
The BA115HP is the ...High Power... version, and says 220 watts in the ads.
Just measure the main voltage rails, and assume the output can come within a few volts of that. So subtract maybe 3-4 volts. That will be peak volts. Time 0.707 for the "RMS" voltage.
RUn a 100Hz signal or something your meter can read, and crank it up. Does the output come up to that level? 26v sounds cool. 220 watts into 4 ohms is about 29-30v, so there is your target.Education is what you're left with after you have forgotten what you have learned.
I ran a 1kHz signal in at 170mV per the schematic. cranked gain and master to 10, EQ flat.
Rails are +/-60V, IC supply is at +/- 17V
As far as test point voltages, I have a few discrepancies on TP 1, 10, 11 & 12, the worst being TP 10 & 12 on IC5A/B
All read on my scope peak-peak (making TP11 ok I think)
TP1 reads the same 170mV input I'm injecting, schematic shows it should be 700mV. TP2 reads correctly though, just downstream of TP1, making me wonder if it's actually ok? I dunno
TP 10 (pin 7 of IC5) reads 1.3V, should be 2.0V
TP 12 (pin 1 of IC5) reads 120mV, should be 800mV
TP 11 (Drain of Q7) reads 42-43 Vpp (30-ish RMS? 43 X .707)
To me it looks like the waveform is bouncing on top of itself slightly.
I would expect distortion to be a clipped waveform (based on my limited knowledge) but when googling images I ran across a picture related to op amp distortion and it had a "smeared" waveform kinda like mine.
I will add that I had "clean/normal" waveforms at all the other test points
Originally posted by Jazz P Bass View PostFirst off, the schematic indicates TP 1 as the input signal amplitude.
700 mvs. (which to me is crazy high)
The next downstream TP2 measured correctly, making me question the 700mV at TP1(with no apparent amplification stage to get from 170 to 700 at TP1) I begin to wonder if it's a typo or my test value is a problem.
Originally posted by Jazz P Bass View PostIt is not clear to me what we are trying to fix.
Run 170mVAC (not peak to peak) at the input jack. Volume & level at 10, tones at 5.
You should get 26VAC at the output into a load. Unloaded should be a bit more.
What do you get at the output?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostRun 170mVAC (not peak to peak) at the input jack.
Are you suggesting I take the test parameter as RMS, then calc the sine wave at 240mV and use that for the input signal?
Seems counterintuitive to me, but I claim ignorant from the beginning
As far as I know, the test parameters are AC volts, which means RMS. Any time the voltage is peak to peak, it will be specified as such. If it's just "AC", then it's RMS.
My point was to look at the big picture first, with specified input do you get specified output. Once you establish that, you can decide whether various points along the line are problems, or just typo's.
It sounds like you are getting the right numbers at the output, it's just in disagreement with your idea of what sounds "loud enough".
The numbers don't lie. But between the output wattage of the amp and your ears is the speaker/cab efficiency.
Edit: I see that Tom P caught a math error that means the output is low and you are not getting the "right numbers".Last edited by g1; 02-23-2016, 10:04 PM.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
