IF you do indeed have continuity from V5 pin 2 & pin7 to V4 & V3, pin 4/5 & 9, then you cannot explain the lack of voltage on V4 & V3.
Something is not being measured correctly.
Is that with tubes in or tubes out? Tubes out, it should drop when they're in. Tubes in, yeah, that's high... I guess if tubes aren't regularly burning out, though, it's okay... the Super Twin I had for a while didn't eat the tubes with 7.1V. Seems +\-10% is allowable for spec.
That's par for the course with no tubes in. All your voltages will be higher, with nothing to pull the current.
Justin
Well the symptoms have somewhat changed since the beginning of this thread and I cannot figure out why. All I have done is clean and tightened the tube sockets, reflowed solder, and take some voltage readings. I have inspected the main board under a magnifier a dozen times looking for incidental solder bridges and cracked traces. When I first got it only 3 of the 4 power tubes would light up other than the lighted power switch itself. Now none of the tubes light up and the power switch flickers when I turn it on then goes out. I have tried different tubes. I ran jumpers from the power tube sockets pin 2 and 7 to the tubes not installing them and they light up just fine. Quite frankly I’m a bit baffled. I would really like to repair this but my knowledge of how circuits’ works is my weak spot. Any thoughts?
You said the power tube flickers, is this the same or a separate issue? When you run the jumpers to the tubes, does the power switch now stay lit?
When you use the jumpers, I assume you only try one tube. How about when you only plug one tube into the socket, still no heater?
Edit: removed info that referred to wrong schematic.
I looked them over several times on both side to make sure I didn't over do it. Deoxed and retensioned them all. What are your thoughts. I could always remove them completely and inspect. I'm guessing I should do that before I go any further.
