Page 1 of 2 12 LastLast
Results 1 to 35 of 55
Thread: Klemt Echolette S...(cont.)
    Old Timer oc disorder's Avatar
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    This is a continuation of a thread originally posted by Translucid titled "Klemt Echolette S"
    re Noteas Klemt Echolette E51 S (the gold one!).
    Nick (notea) is in France and despite my inability to speak French (I knew those French lessons were useless way back at school ..not much help to me now!!! ) he is testing the components around the ECC82/12AT7 and measuring the voltages while we try to determine why the bias oscillator is not working.
    Any contributions welcomed !
    notea wrote-
    "I'm back to this beast, and I did the reading anti-clockwise this time of the ECC82, and it's seems that we've got the proper values here except that there is no DC at pins 3 & 8.
    Pin 1= 300V, Pin2= 100K, Pin3= 470 ohms+ 0 DC, Pin 4&5= 5V AC, Pin6 = 305V, Pin7= 100K, Pin8= 470 ohms+ 0 DC, Pin9= 0 AC
    can't explain why there is no DC at pins 3 & 8?
    "If there is no DC at pin3&8 of the Ecc82 it's because of the osc coil that doesn't work properly."
    - So I checked the lug of the 0.1 uf cap and there is no voltage at all,
    - So no voltage on L2 and 300 VDC on L1, that's mean the cap is dead right?
    - I don't know where the test point is on the osc coil for the 270V AC so i checked each lug and I got nothing except
    where there is the DC coming (I read 600-650 AC)
    Cheers, Nick"
    Hello again, we just had a long weekend celebrating the 8 hour day in Aust. but the way things are looking "dunno" (translation = don't know) if we will be celebrating this for much longer !!
    "the cap is dead right?"
    Wish I could give quick answers ... well I'll try... maybe.. if you are referring to C18 the 0.1 (500v?)
    that taps off the secondary of the oscillator coil L1 and supplies the Erase head with a high freq
    AC signal that normally erases the tape.
    If it is shorted the resistance of the erase head may drag down the secondary voltage although
    it may be too much for the erase head and it too could short (inside wires melted together) or go open circuit (internal wire melts/breaks) meaning there is no resistance reading from the head.
    Try unsoldering one end and see if a voltage appears at the ECC82 cathode pins 3 & 8.
    We now know that the 2 x 100k resistors on the grids are ok and the cathode resistor 470Ω
    is also ok.
    That leaves the tube/valve, the Oscillator Coil (transformer) and the capacitors that could be broken.
    The tube is easy to test , just put in one that is known to work or a new one that works.
    The Oscillator Coil is a difficult one... would have to get a second hand (used) one or have some expert rewind it at great cost ..I don't know of anything suitable at the moment so we will keep our fingers crossed and hope it is ok.
    The capacitors we can change fairly easily.
    They can change their value , and this upsets the circuit as it wants to resonate vibrate ... um oscillate !
    I think it's more likely the 3 capacitors connected to L2 have drifted from their value.
    From your photos the capacitors look "old waxy style" and after heat and many many years
    their capacitance in farads may have changed.
    So lets replace all four which should not be expensive.
    From the NG51S schematic
    C18 = 100000pF = 100nF = 0.10uF Check the voltage on the old one above 350vDC should be ok.
    C19 and C21 = 200 pF = 0.20nF = 0.00020uF silver mica 500v?
    C20 = 1000pF = 1nF = 0.001uF 500v good here too.
    "I don't know where the test point is on the osc coil for the 270V AC so i checked each lug and I got nothing except where there is the DC coming (I read 600-650 AC)"
    We wont get the AC as it is produced by the oscillator which is not oscillating.
    E.g. Our power outlets in the home ..110vac or 230vac at 50 or 60 HZ (Hertz = cycles per second)
    The oscillator is probably about 60,000HZ or 60KHZ very high vibration !!
    With some multimeters they can give strange readings where oscillators are involved.
    It's almost transmitting as it is vibrating at a very high rate when it is working :-) !!!
    So you have some shopping to do . You may like to trace the erase head connection and see if it still
    measures resistance like you did with the record heads.
    It may be a bit different to the 1.??K .
    I'm fairly sure its wire connects to that 0.1 on top of the coil.
    | Farnell element14
    http://fr.rs-online.com/web/c/?sra=o...EUR+200pF+500v
    Further reading on things that flip back and forth (oscillator)
    https://www.youtube.com/watch?v=WkipSDmoOHU
    Astable Multivibrator (Oscillator)
Name:	Echolettes- S NG 51 & E 51 Bias.jpg
    Oct 2014
    113
    Hi, back from my trip down south and have just read the responses to your issue. Can you borrow, beg or steal an oscilloscope? If so you can quickly check the waveform from the oscillator on the erase head, it should be approx 60Khz at a AC voltage of approx 80V. The oscillator transformer is a very robust device and will most likely be alright. Have you checked the 1uf capacitor on the 470 ohm feed resistor? Also have you measured (from either pin 3 or 8 of the 12AT7) to ground, this should measure 470 ohm. Replace the capacitor that goes across the anodes with a .001 uf 630v capacitor, make sure this is a high voltage capacitor as there is a large AC component across the anode windings. My advice is to replace one component at a time then check for a result, as often when a blanket component change is made chances for a wrong connection are multiplied. Good luck.
    Feb 2015
    84
    Hi and thanks both of you,
    - Oc, i've unsoldered on lug of the C18 cap to check if there was DC on pin3&8 and there is not.
    - i've checked the resistance first directly on the erase head at the top of the unit, then on the c18 lugs and i get an infinite reading so i guess the head is open, i hope it's not broken though? otherwise i may have to order one..
    - Mickey, i don't have an oscilloscope but i'm thinking of stealing one somewhere as you suggested me.. I did the AC measurement on the erase head and i don't have any voltage.
    -"Have you checked the 1uf capacitor on the 470 ohm feed resistor?"> sorry i don't know where it is, could you label it for me?
    Next step is ordering components, as soon as i get them i'll do the cap job.Hope i don't have to order a new erase head..
    I might need some advices for the osc coil before i bugger it (i try aussie slang!), i'll unscrew it from the top of the unit, label the wires, but do i have to unscrew the bias screw in the middle of this square tagstrip or leave it alone?
    Cheers Nick
    Oct 2014
    113
    Hi Nick, with the valve removed you should measure 470 ohm from either pins 3 or 8 to ground. C18 is the feed to the erase head and would have no effect re R37 (470 0hm). R37 is the cathode resistor for 12AT7 (Rohr 5). An open erase head will not stop the unit from working, you would end up with infinite echos.
    The 1uf filter (bypass) capacitor is wired directly to the bias oscillator transformer where a 470 ohm resistor feeds the HT to the primary coil. It's value is not critical as I usually replace it with a 10uf 350V capacitor. On some schematics this capacitor is not shown near the oscillator coil. I believe it is C47.
    Leave the oscillator coil ALONE!!!!!! To check the erase head just measure across it, should measure about 3 ohms. Again your problem will NOT be in this area of the circuit.
    Good luck and keep us posted, Mike
    Feb 2015
    84
    Hi Mike,
    i doubled check the readings on pin3&8 of the ECC82 and i've got 470ohms so i guess it's a good news,
    my worry is, to access those caps i might need to remove the osc coil as suggested Oc in previous posts?
    but i'd like to do this this in a proper way,
    it looks like it is held just by one screw on the top of the unit and i suppose i don't have to touch the bias screw to pull out the osc coil?
    What could be another way to replace those caps without removing the osc coil?
    I'm ordering the parts tonight, can't wait to have them!
    Cheers Nick
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Hi again.... I cannot see how a tech can get to the base of the Osc. tube without removing or moving the osc. coil.
    To undo the chassis to gain access seems like a nightmare to me. Perhaps a can opener? or as a friend did once.. used a nibbler
    to cut a big hole and then made a plate to cover the mess !!! (not an echolette I might add !)
    Nick , with the erase head if you have good eyesight or in my case use a jewelers eyeglass ( for magnification ) gently check
    the fine/tiny wires under the solder blobs ...
    Quote Originally Posted by Kazooman
    "I believe that Bobby Staedel rewinds Echolette heads.
    I have no idea what this would cost and you need to figure shipping to and from Germany."
    bobbysreparaturen.de
    I think he does a swap providing yours is in good condition well ... apart from the broken wire - which he can rewind later.
    Does anyone know if a changed load on the secondary winding would stop it oscillating ? i.e. lack of a low ohm load as in open erase head?
    Reflected impedances and all that..
    Nick .. when the parts arrive just try replacing the 1000pF across the coil first as Mickey suggested.
    The cheesehead straight slot screw (about 1cm) on the top is just a mounting screw, there is no bias adjustment at the coil.
    Oct 2014
    113
    Hi again, many years ago I had valve extensions ( both home made and professional) these allow me to measure voltages and waveforms without having to dig deep into the innards of a repair item.
    As for reflected impedance I would think that the oscillator circuit used in an Echolette would not be affected by O/Cs or S/Cs. Many of the better quality tape recorders used the multi-vibrator circuitry as it is far more stable and can supply higher bias/erase currents.
    I'm concerned that Nick is in to deep already and that he should stop digging the hole which may end up with another Echolette on the scrap heap.
    Maybe he should re-iterate what his initial problem is and what he has found so far. As they say "make haste slowly"
    Cheers, Mike
    Oct 2014
    113
    Hi Nick, I wouldn't replace those caps which are located hidden behind the coil. These are styroseal low value caps and unlikely to be faulty, even the .001uf one. Fit a ECC82/12AU7 and check for 11V DC at the cathodes of this 12AU7. If you are adventurous solder a piece of thin wire to the positive test lead and then if you pry the valve up a little you should be able to measure the voltages on the pins of the valve with the power switched on. The anodes of this 12AU7 should read approximately 290V and you should have no voltage at the grids, if you do have voltage at the grid you either have a faulty valve or the coupling capacitor is faulty (leaky!)
    Having a 12AT7 in Rohr position 5 makes me wonder if a previous owner tampered with this unit. Have a close look for any obvious mistakes such as incorrectly connected replacement resistors or capacitors.
    Cheers, Mike
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Whoops had a mental block my apologies
    ECC82 = 12AU7
    Think I picked it up here
    http://music-electronics-forum.com/t...6708/#poststop
    Feb 2015
    84
    Hi, i checked the tiny wires of the erase head, there was a bit of dust that i cleaned but they seem fine.
    - I put the ECC82 in place, let a tiny space to see the pins and measured pin1,Pin3&8,
    it was a bit tricky and i hope the fact that the tube was not completly pushed down doesn't effect the readings too much..
    -anyway, i hardly measured 260VDC on pin 1 and from time to time the meter went crazy (perhaps the fact that the tube is not completly pushed?)
    - On pin 3&8 i measured 5VDC (by the way sorry for this learner question but i don't know why without tube i should have read 11V and 0 V with the tube in place?)
    So i will order a new ECC82, and may be 'll try to replace C18 as soon as i receive the parts, cause it's easy to change
    i'll be away this w-e but early next week i'll do a recap of my problem with all the readings i made on each tube and tapeheads,
    including a recap of your advices for this step by step troubleshooting since the begining.
    Cheers Nick
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Yes Nick the 11 volts DC is only there when the tube is conducting. Sorry I just assume that.
    When the ECC82 is not plugged in , there is nothing connected to that 470 ohm cathode resistor
    (R79) except ground and 2 empty pin sockets :-(
    It does seem to be partially working.
  12. #12
    Oct 2014
    113
    Hi Nick, did you measure the voltage at pin 6? This should be the same as pin 1. Your erratic metr readings are most likely caused by the pins on the valve being slightly oxidised so a good contact is a matter of perseverance.
    If you are measuring 5V at pins 3&8 that may suggest that the oscillator isn't working as it should, that is why you should also measure pin 6 which is the other anode.
    If you are still having problems identifying the connections to the oscillator transformer, they are as follows: Looking from the top with the back of the NG51 away from you,
    pin1 top LHS goes to ground, pin2 (next one down and it is only a connection point) goes to the erase head, pin 3 has capacitor feeding erase head connected, pin4 goes to record heads. On the RHS pin1 (at the top) is the B+ input, pin2 goes to ECC82 anode, pin3 goes to other ECC82 anode. The LHS windings are the secondary while the RHS windings are the primary.
  13. #13
    Feb 2015
    84
    Hi,i'm back to the "gold cage"
    First i wanna Thank you guys again for all your advices,and guiding a beginner like me trough this piece of machinary..
    This is a recap of our work since the begining:
    troubleshooting the Echolette NG51s with no echo.
    The visual indicator does respond when the signal is applied
    TUBE READINGS:
    Tube n1:
    Pin1&6=230V
    no ohms readings on the other pins
    Tube n2:
    Pin1=199V,Pin2=162K,Pin3=992ohms,Pin6=290V
    Pin7=990ohms,Pin8=343ohms
    Tube n3:
    Pin1&6=136V, no ohms readings on the other pins
    Tube n4:
    Pin1=202V,Pin2=1000k,Pin3=988ohms,Pin6=227V
    Pin7=1000k,Pin8=2k20
    Tube n5(ECC82):
    -without tube: Pin1&6=300V,Pin2=100k,Pin3=470ohms
    Pin6=300V,Pin7=100k,Pin8=470ohms
    -with tube pluged in:
    Pin1&6=230V,Pin2=100k,Pin3=470ohms+7V,
    Pin7=100k,Pin8= 470ohms+7V
    TAPEHEADS
    -I measured 1k14 ohms for each except the erasehead that seems open
    * with the reverb control fully clockwise i touched the head gap of the replayheads with a screwdriver as suggested Mickey
    and i can hear no sound coming from the amp
    -I measured the trim caps
    "The voltages you measured are for record head 3 & 2. You only need to measure where
    the head connects to the variable capacitor.For head 3 you measured 45 volts .. (according to Kazooman) this should be 120 volts AC @ aprox 60kHZ.
    For head 2 you measured 30 volts this should be 90 volts AC @ aprox 60kHZ.I suspect head 1 ('s) reading (which is hard to get to under the rectifier) would be lower 10 or 15 volts so
    I guess the oscillator is low on the output.Oc Disorder"
    -stange thing is i got AC on trim caps but i can't find any 270V AC on the osc coil..
    -i Have 7VDC at pin3&8 of the ECC82 with the tube pluged in.
    I'm still waiting for the parts and the new ECC82, i will replace the 0.1uf (C18) but we're not sure it's gonna solve the problem.
    Cheers Nick
  14. #14
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Hi Nick , that C18 (0.1uf) is in series with the erase head so if the erase head is open you won't get any change by fitting the new cap as only one end is connected.
    To satisfy my curiosity while you are waiting could you solder a say 10 ohm resistor across the erase head (this places a load on the coil's secondary) and try measuring the 270vAC again ..could also check the ~30 and ~40 volts AC at the trim-caps.
    This is sticking my neck out (well you are in France) ... that C18 may be faulty and have contributed to the erase heads demise!
    We haven't checked the playback heads yet for continuity. They terminate in the bowels of the machine unfortunately.
    Anyhow first hopefully you can get the osc. working.
    One possible problem we haven't dealt with is the possibility your multimeter is not capable of measuring AC which is oscillating
    at a high frequency.
    This is why suggestions have been made to borrow an oscilloscope.
    A more expensive meter with a large bandwidth may solve this too if you could borrow one.
    Some further reading:-
    Post #15 here
    http://forum.allaboutcircuits.com/th...-voltage.7607/
    and
    https://groups.google.com/forum/?hl=...cs/hX73zE2f0nM
  15. #15
    Feb 2015
    84
    Hi Oc, ok that makes sense.. But i feel a bit lost right now, don't know what to do except replacing C19/20/21 but as Mickey said "These are styroseal low value caps and unlikely to be faulty"
    and i have this 7V on the ECC82 so that means there not dead?
  16. #16
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Well , so far so good we or you know a lot more than we did in the beginning. The fact that you measured 7 volts means it's partially working and we can count on that being a good indicator.... i.e. the meter can read DC ok !
    Usually this means the tube or the components immediately near/around it must be faulty.
    I saw where Mickey mentioned that normally the stryoseal caps are unlikely to be faulty but we should be thorough and methodical and check these after replacing the tube. There isn't much else that could go wrong apart from a dead conductive moth or bug or spider across the tube socket - it does happen !
    Re reading your notes , while you are waiting for parts we should look at why the Magic Eye is not Magic at the moment.
    Possibility could be just the tube. I'll have a look and think about it.
    I re read your notes from the earlier thread and I see the Magic Eye is working but only on the live signal (no Echo indication).
  17. #17
    Oct 2014
    113
    Quote Originally Posted by notea View Post
    TUBE READINGS:
    Tube n1:
    Pin1&6=230V
    Tube n2:
    Tube n3:
    Tube n4:
    Tube n5(ECC82):
    TAPEHEADS
    Cheers Nick
    Hi Nick,
    From your above list I think there are a few discrepancies.
    If the visual indicator closes and overlaps when driven strongly I would forget about valves 1 & 2 for the moment, as it appears that their circuitry is working as designed.
    Valve 3 pin1 should read approximately 75V with the valve plugged in
    Valve 3 pin 6 should read about 75V with the valve plugged in.
    Valve 4 pin 6 should read about 100V with valve plugged in.
    Valve 4 pin 1 should read about 200V with valve plugged in.
    Is there approximately 300V coming from the power supply rectifier and have you bridged any/all filter caps?
    If an anode voltage is considerably higher (eg 175V instead of 120V) it indicates that the valve is not drawing current, if the voltage is very low (eg 120V instead of 175V) this indicates that the valve is drawing higher current.
    Check if there is a +ve voltage on either pin 2 or 7 of valve 4, but before you do re-check the anode voltages. A positive voltage could indicate a leaky coupling capacitor.
    I would suggest that you have valves 3 & 4 working correctly before going any further. With care you can touch the grids with your finger (via a screwdriver) and you should hear a buzz in your amplifier. You would need to turn up reverb control (nachhallstarke) and work your way backwards from right to left on the schematic.
    Let us know your observations.
    Mike
  18. #18
    Feb 2015
    84
    Hi Mike i've got good news from the readings that you've suggested,
    Valve3: Pin1&6 =70V when tube pluged in
    Valve4: Pin1=74V and Pin6=167V it's a bit low but could be a matter of tweaking some pots perhaps..
    -I've got 290VDC from the power supply rectifier and 213V AC.
    -there is no voltage at Pin2or7 of Valve 4!
    -I touched with a screwdriver Pin3&8 of each tube with reverb control fully clockwise and i can't hear no buzz at all coming from the amp
    Oc, the magic eye seems to respond to the signal even on echo mode.
    But something happen with this preset:
    with reverb control turned up, and the head 1 button at zero.
    At this point i've got a sort of ugly metalic overdriven sound with a bit of wobble (not sure with the word) as i play with the reverb duration button. And the magic eye is clipsing.
    As i slowly turn the head 1 button clockwise the magic eye stops clipsing and i lose this "wobble overdriven sound", and the reverb duration button doesn't respond anymore.
    This "thing" occurs only with the head 1 button, the second and third doesn't do anything.
    I'll study the schematic carefully but it's confusing at my level, i didn't have the chance to build an audio probe test yet but i soon as i have, i'm not sure if i'll succed to trace the signal
    in this narrow jungle of wires..
    Nick
  19. #19
    Oct 2014
    113
    Hi Nick, If you trace the signal from your amplifier backwards you can see from the schematic that it travels back to anode of valve 4 via C5,R65,R57,R50(REVERB CONTROL),C31 to pin1 on valve 4. This valve is driven by the other half of valve 4 via C22 and R29. The signal can then be traced back to valve 3 via C9, R16 and R15 and to it's input grid from the tape head, pin 2 on this valve (valve 3).
    So working backwards and touching each grid as you go along you should be able to get a buzz in your amplifier which should get louder as you reach pin 2 on valve 3.
    Check to see if this part of the circuitry is working and then we'll go from there. Don't do anything else until this section is working reasonably well.
    This is also easily seen on the Echolette S detailed schematic I sent you
    Mike
  20. #20
    Feb 2015
    84
    Hi Mike, the only thing i could say for the moment is that there is no noise when taping the pin2 on Valve3, i got a slightly scrachy noise on R65 of valve4 but after it's to hard for me to see, get in or even recognize the proper component..
    it's harder than i expected..
    cheers Nick
  21. #21
    Oct 2014
    113
    Hi Nick, First of all let's get the right schematic. If you have a very early non-printed circuit board NG51 your schematic wouldn't have an R65 which is the anode resistor for the first half of valve 4. That resistor would be R30. Although the circuits are very similar and will make it a lot more difficult if you and the other contributors are working from different schematics. That R65 you refer to would be 200K and would have HT on both sides.
    Again I think it is easier if you pull a valve out slightly and then measure or touch (whatever) the appropriate pin.
    Did you get a reasonably loud signal on the output din socket (pin 3 on this socket) from which the signal goes to your amplifier? As I noted previously, once you have ascertained that buzz then work back to valve 4 and then to valve 3. Just be a little careful that you don't short pins together and that your other hand doesn't touch the chassis. The grids are always either pins 2 or 7.
    Let me know what signal you obtain working backwards and touching the pins with your finger via a small screwdriver. If for instance you get a good buzz on pin 2 of valve 4 but nothing on pin 7 then there is a fault in this part of the circuit. If you don't get a good signal on either grids of valve 4 swap valve 4 with valve 1 or 2.
    Cheers,
    Mike
  22. #22
    Feb 2015
    84
    Hi, great progress here!
    You're right i don't have the right schematic it seems that this unit is an early one.
    Mike i followed your procedure first i checked the output din socket and no buzz at all, then i checked valve 4 pin 2 and i was happy to here that buzz!, then nothing on pin7(valve4).
    I moved to valve 3 and i got a loud buzz on each pin (2&7)
    The faulty components could be C8? C9? (i found an another schematic but in bad quality, too pixelized i can't hardly see the label of the components)
    I know that the resistance is ok cause i measured 1000k on pin7
    what i doesn't understand is why i've got the signal from the guitar but no buzz on the output Din socket?
    Thanks Nick
  23. #23
    Oct 2014
    113
    Hi Nick, Are you telling me that you can't get a buzz in your amplifier when you touch pin3 of the Ausgang din socket of your echolette? I believe it is a "pink" wire, and if this is the case then you have a faulty lead or maybe C5 (.01) or C35 (.0022) has shorted, but I would think that you aren't locating pin 3.
    Fix this issue first and then work backwards.
    Now that you have established the right model for your echolette do you have the right schematic, should be available on the net.
    Cheers,
    Mik
  24. #24
    Feb 2015
    84
    Hi Mike, i 've got a buzz on pin 5 of the output din socket according to the schematic, hope i'm right..
    the order on the schem is like this:1-4-2-5-3 clockwise
    i've soldered pin 2 and 3 on the din plug as i read on the internet, but that doesn't explain why i can hear the guitar signal trough the amp..
    what do you think?
    cheers Nick
  25. #25
    Oct 2014
    113
    Hi Nick,
    Just remembered a point, you will need to have the echo button switched on (first button on bank of 4 white switches).
    Now if you remove your din cable from the echolette locate the pin which provides a buzz through your amp and then find the corresponding connection on the din output socket of your echolette. If you look at the schematic pins 4 & 5 should hav the direct non-echo signal coming from the input srage of the echolette, and pin 2 should be ground. Pin 1 would be a lower level output signal.
    You have to find the signal going from the echolette to your amp before we go any further.
    Cheers,
    Mike
  26. #26
    Mar 2015
    In France, near Bordeaux
    33
    Hello
    I own an Echolette NG-51 S, but i am not sure of the tape heads location.
    For record heads, i think , when going from right to left, we have 3,2,1 heads.
    But, my doubt is for playback heads!
    After record head n1, (always from right to left) is it head n4 or n5? Please?
    My Echolette was modified by the previous owner, & i am
    not sure that heads 4 & 5 are in the good order...
    If any one could inform me, thanks to him!
    Best greetings from France.
  27. #27
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Hi Nick ,
    Couple of diagrams that may be useful. See if your Echolette is the same layout as the one I'm working from.
    Although this one has a different style motor and originally had din input sockets from your photos I think they are the same.
    The tube the ECC83 as you know has 2 identical halves .. well its a dual triode. Sometimes pins 1,2 & 3 are transposed/swapped
    with 6,7 & 8. Once you find the heaters pins 4 & 5 it makes it easier.
    On the schematic I show the pathway for the guitar signal to pin 3 of the output and also the pathway for the echo sound from the tape head.
    On the "layout" diagram with photo I included the 3 schematics for tube 4 I had with their respective titles from the schematics.
    Although the component numbers can change the actual values and pin numbers remain the same .. well most of the time !
ID:	33312   Click image for larger version.
Name:	Echolette S Type NG51.jpg
  28. #28
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Hello Mecaso
    see #4 here (a gif)
    http://music-electronics-forum.com/t37002/
    Wiedergabe Kpfe = Playback heads
    Aufnahme Kpfe = Record Heads
  29. #29
    Mar 2015
    33
    Quote Originally Posted by oc disorder View Post
    Hello Mecaso
    see #4 here (a gif)
    Hi, oc disorder.
    Thanks for your answer, but....., sorry, i don't see where tape heads n4 & n5 are located.
    I see the playback heads, of course, on the left of the diagram, but not which is the
    n4 or the n5.
    When the "nachhalldauer" button is pushed, is it the playback head near the record head n1 which works, or is it the playback head near the plastic guide roller which reads the tape?
    This is my doubt...
  30. #30
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Hi Nick ,
    Here's a picture and rough layout of where the playback heads terminate. You should be able to check the resistance here.
    Mecaso
    The normal or logical order of heads would be
    ----- >[ERASE] [REC 1] [REC 2] [REC3] [PLAY4] [PLAY 5] ---->
    I would count from erase in the direction of tape travel.
    Yes No 5 playback head has a shorting switch on it.
    It is a pull switch on the Reverb Duration control "Nachalldauer" .
    This diagram for Nick should help you too.
Name:	Playback Heads Termination.jpg
  31. #31
    Mar 2015
    33
    Hello
    Thanks...but, for record heads, in the direction of tape travel, after the erase
    head, the first head is the n3.
    It is it which gives the longest echo.
    So, the normal order after erase head would be 3, 2, 1, 4, 5.
    Regards....
  32. #32
    Oct 2014
    113
    Quote Originally Posted by Mecaso View Post
    Hello
    Hi, both record and playback heads should measure approximately 1K ohms. Old NG51 Echolettes suffered from head problems mainly the record heads (from my experience) and I believe this may have been partially caused by the "high" bias oscillator voltage assisting the wire corrosion problem that besets these heads.
    Could you provide details of the issues you are experiencing or what you are trying to improve.
    Regards, Mickey
  33. #33
    Jul 2006
    Land Down Under
    1,268
    Received: 1/0
    Given: 1/0
    Mecaso
    I guess its "the playback head near the record head n1 which works" as that head as it is so close it would be a very short echo more like reverberation etc .. the one here had heads replaced so the wires could have been swapped.
    When I look at the picture , heads 4 - 1 - 2 - 3 are evenly spaced apart.
    5 is the extra.
Name:	head order.jpg
  34. #34
    Mar 2015
    33
    Hello
    Sorry, Mickey, i don't try anything, but i only search the order of tape
    heads from right to left of the NG-51 S.
    All my heads are in good shape. I have bought my Echolette in ......1967.
    It was second hand, and i used it in my orchestra from 1967 to 1973.
    But i have keep it at home.
    I have others tape echoes:
    - 1 Dynacord Echocord S-62 a
    - 1 Dynacord Echocord 100
    - 1 Echolette Echo 400
    And it is when looking at Echocord S-62A diagram that i had a doubt
    with location of Playback heads on my echolette NG 51 S.
    On S-62 A, the tape heads are in this order:
    3, 2, 1, 5, 4.
    On my NG-51 S , this order is 3, 2, 1, 4, 5.
    So, i think that tape heads 4 & 5 are in disorder on my NG-51 S.
  35. #35
    Mar 2015
    33
    Mecaso
    5 is the extra.
    OK Now, i am in accord with you.
    I think it is the good order.
    On my NG-51 S , heads 4 & 5 are permuted, and i don't know the reason why.
    So, i'll permute this heads to put them in the good order.
    Thanks again & regards....
  1. Klemt Echolette S
    By TransLucid in forum Guitar Effects
    Last Post: 08-21-2018, 05:17 PM
  2. Klemt Echolette E-51 trim pots and tubes location
    By nisios in forum Music Electronics
    Last Post: 05-09-2018, 10:10 AM
  3. Replies: 0
    Last Post: 08-13-2012, 08:13 AM
  4. Klemt Echolette S NG51 for sale - mint condition!
    By mikefordham in forum Guitar Effects
    Last Post: 01-10-2012, 05:38 PM
  5. Klemt Echolette Grounding Question
    By Kazooman in forum Music Electronics
    Last Post: 03-03-2011, 03:44 PM
