Trace Acoustic TA60CR schematic
  • Trace Acoustic TA60CR schematic
    Would anyone have a Trace Acoustic TA60CR schematic available?
    Thanks in advance.
    Drewline
    When was the last time you did something for the first time?
    Have you tried calling customer service at Peavey? Trace is one of their brands. worth a shot.
      I emailed Trace & am waiting for a reply. I hadn't realized they were a part of Peavy until I saw their address. Thanks!
      Drewline
        In the meantime, you are welcome to see if the100/50R is close.
          TA30, TA50 & TA100, these may be close enough for you
            Thank You for the schematics. I will post the TA60 when received.
            Drewline
              TA60CR Service Manual
              Here it is.
              Trace Elliot TA60 CR Service Manual.pdf
              Steve
                Thanks so Much!
                Drewline
                  TA60 Schematic
                  I just received an email from Trace Elliot with the TA60 schematic. As promised here it is:
                  Drewline
                    Same file as posted above.
                      Well, twice as good then.
                        Just doing what I said I'd do. I try to share as many schematics as I can. We've been building a large schematic file for the past 3-4 years.
                        Drewline
                          Understood.
                          I just wanted the fact out there.
                            A friend found a deeel on a non working amp at a thrift. So.... Now I need a number on a transistor for a Trace TA60 CR Acoustic Amp. The amp must be an older version prior to the Penguin schematic that is offered here, as the TR-2 on the output board is shown as a TIP31c with a TO220 case. The item which was cracked and encrusted with thermal grease was a TO-92 case, much smaller, but was mounted in a silk screened circle on the board not like a TO220 case which is a square printing on the board. I need to know what the old circuit was to make a choice of replacements. I pulled the broken one out and the number crossed to a 2n3409 among others, but when I tried to confirm the cross ref I couldn't find it again. It is probably now in the vacuum cleaner. So long story to short, is there a pre penguin Service manual out there anywhere for the TA60CR? Thanks
