AC Outlet
I'm guessing its somewhere in Poland....kidding! Those look like the old amp (Fisher/Dynaco) AC outlets they had in the back and are very hard to get. People sell used pulls for $10-20 on fleabay!
Sansui QS 500 Amplifier Parts AC Outlet | eBay
I'd nibble a little bit bigger hole and use the snapins like this
http://www.amazon.com/Panel-Mounting...f=pd_sxp_f_pty
The only use I can see for them is restoration where a collector wants it exact and accurate. You can find usable ones in a variety of old hifi amps dumpster diving. They used them for switched power for turntables. If it's a new build, or even a non-collector repair, use a modern design or disconnect it IMHO.
The problem in a Sunn amp is that they break real easy. All it takes is a lateral tug on a cord plugged in there. Since the line cord hot and neutral solder to directly to the outlet, removing is a pain. You have to install a terminal strip or go with wire nuts.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
