Replacement Input Jack for Eden Nemesis N12
I'm assuming this is a surface mount jack? Have you tried MCM? If you can't find the right configuration, but it will mount to the board correctly, you can always cut the traces (if it isn't double sided!) with a dremel and just cross some fly wires. I've done that. There's a lot of McGyvering you can do with a little imagination.
Originally posted by 52 Bill View PostWelcome to the place. Have you tried contacting Eden?
What's wrong with the original part? I've seen that same problem before, but I don't think it was an Eden amp.
I will ask my local trader today afternoon.
Yeah I had to repair a jack on a Granger amp just exactly like the one on your amp. Tooth picks and super glue was call of duty that day... I am one of those guys that loves to figure out ways to fix crap that other people would just replace. Anyhow on the Granger web site they have a similar version of your jack in question, but it won't work. I did find a source for the part on FleaBay and at a decent price. Note that this jack has a L-Leg jack pc mount style. Could not see the bottom of the jack you have there, but pretty sure many of these will have L-Legs. What does your jack have?
Cliff 1 4" L Leg Jack Stereo 6 Pin PC Mount Fender GK | eBayWhen the going gets weird... The weird turn pro!
