Reverberocket 2 volume dropping when increasing tremolo intensity
  • Reverberocket 2 volume dropping when increasing tremolo intensity
    Hi
    The more I increase my Reverberocket 2'a tremolo's intensity the more the amps volume drops.
    It also sounds like it's reducing the reverbs volume.
    When I turn the intensity back down to zero everything goes back to normal.
    Cheers.
    Based on the schematic in your other thread, the intensity is a 4M pot in series with the first stage signal. I would imagine it would cut the signal a bit when turned to the 4M extreme.
      I did some more research and it looks like my Tremolo Bug needs to be replaced.
        if it has the pink molded axial coupling caps save time and replace them all.
        The Wimas are usually all good.
