Well, i think for the first time in 10 years of working on amps ive actually run into a Bassman AB165 head with a cconductive eyelet board. All amps that ive run into with this issue (crackling, hissy) in the past, ive managed to fix replacing components. This one is extra tricky and has had me pulling components AND my hair out. I stuck my meter probes into the board and get 8Mohms in certain spots, it varies depending on location. Sooooo, really in all truthfulness, how many of you have actually dealt with this issue. I know some techs assume this before actually figuring it out. I'd like to know how common this has been for you all, and do end up replacing the entire board or just part of it? Oh, and I wouldnt think 8Mohms would really cause an issue.
Conductive Eyelet Board
8M is what your ohm meter measures by putting a volt on the board. Now put 400v on the board, now what? Instead of measuring resistance, turn the amp on and ground your meter and measure voltage on the board instead of resistance.
I have encountered this any number of times over the years. I have had success using a heat gun. Ever watch your frosty car windshield slowly defog when the heater blows on it on a cold day? You can watch the thaw line move across the fog. I blow hot air from my heat gun on the board, and watch the appearance of the circuit change from waxy looking to a more matte finish. As I play the hot air on it, I can watch that "thaw" line move along the board. I work from end to end until the whole thing is cleared. I have found this works for me a lot better than other methods with cleaners and solvents.Education is what you're left with after you have forgotten what you have learned.
2v from board to ground...also, I unscrewed and raised the board and the problem goes away....so i guess there is some conductivity between boards and therefore from eyelet board to chassis ground. Seems that replacing the isolation board should do the trick, right? (Probably be a while b4 i locate my hear gun)
Originally posted by lowell View Posthow many of you have actually dealt with this issue. I know some techs assume this before actually figuring it out. I'd like to know how common this has been for you all, and do end up replacing the entire board or just part of it? Oh, and I wouldnt think 8Mohms would really cause an issue.
I rebuild the afflicted audio circuits on tie strips bridged over the black board. If DC stray current is going to leak here there and everywhere, let it. It's not going to jump thru the air and get on the phenolic tie strip material. The total solution is replace the board with a proper turret or eyelet board built on a better material like epoxy-fiberglass but that gets expensive and time consuming. No amp owner I've met wants to spend that kind of money so the tie strip method works for us.
8 Megs is plenty enough to raise hob with your audio. All kinds of noises crop up as you mentioned plus pops & squeeks that sound like bad tubes. On occasion I've even found cloth-insulated wires sandwiched between the circuit and underboard pick up noises thru unexpected conductivity of their "insulator" layer, they need to be replaced too. It's a noise jungle in there.This isn't the future I signed up for.
Originally posted by lowell View Post2v from board to ground...also, I unscrewed and raised the board and the problem goes away....so i guess there is some conductivity between boards and therefore from eyelet board to chassis ground. Seems that replacing the isolation board should do the trick, right? (Probably be a while b4 i locate my hear gun)
I've seen my share of conductive circuit boards. Always the black paper turds. I've seen two that became conductive without being in high humidity. Where Enzo's heat gun method didn't work. With the amp stored and/or used in appropriate climactic conditions to be sure and still conductive and I had to replace the board. I suspect excessive soldering heat or repeated heating and HV can align the carbon used as a pigment in rare cases and conditions. One was a customer amp that I was doing extensive mods to and the other was a personal project that I had already worked on a lot. I've seen two other black turd boards that were acceptably repaired with heat, but not 100%. I don't do repairs professionally and probably haven't seen a dozen black fiber boards so four of those seems like a disproportionately high number to me. I've said it so many times that long time members her will be sick of hearing it from me. I hate those black paper boards."Take two placebos, works twice as well." Enzo
Not suggesting you do it if you are charging a customer by the hour and you want to make it work ($$$$/time) for both you and him, but in some cases where it's an amp I own or customer is fed up with "ghost" problems and gives me the green light, I have cloned the board out of 2mm Pertinax, the brown phenolic material, and transferred parts and wiring.
Yes, it takes most of a rainy Saturday or Sunday afternoon, not justified on a busy weekday, but it cures the problem forever.
I also drill old self tapping screw mounting holes out and use standard 1/8" bolts and plastic separators, so no need for the "insulating" board but the new eyelet board is 1/4" away from chassis.
It really cures the problem forever.Juan Manuel Fahey
Ask Randall, indeed. The amp I built with the black fiber board changed what voltages I could measure on various parts of the board over a 3 day rainy spell we had a couple of springs ago. Scratchy pots, weird sounds, voltages that didn't make sense. And it decreased with the heat treatment, and came right back later. Proof enough for me. It was a full two months before I could bring myself to continue on with that project, I was so mad. I ended up replacing the entire board with a nice epoxy-glass turret board, and never looked back. That amp was as quiet as a mouse pissing on cotton after that.It's weird, because it WAS working fine.....
Originally posted by Randall View PostThat amp was as quiet as a mouse pissing on cotton after that."Take two placebos, works twice as well." Enzo
When I first started doing turret boards I got my stuff from turretboards.com.
Bare board: Circuit board material
Bassman circuit boards: Circuit boards
If you want to source your own stuff, I have bought the G10 from McMaster Carr and Keystone Electronics makes the turrets which I bought from Mouser. Anvils and stakes can be fabbed from standard hardware store bolts. Add in a drill press and you're making turret boards.-Mike
Originally posted by gbono View PostI have a 66' bassman that I suspect has this issue. Where do I get a good turret board - as mentioned? maybe just use a piece of "bare" FR4? Not going for concourse judging on this amp
I'm sure Watts / turretboards as defaced suggested could do it. If you want to shop price or for a nearby source check Hoffman.This isn't the future I signed up for.
+1 For Hoffman. I forgot about them, but I have bought many things from them and they've always been good.
Regarding the staking tool, the Keystone staking tools are sized for various terminals - I think the sizing is listed in the Keystone catalog. I've always wanted to buy one of the real stakes, but I went the cheap route and bought a center punch that I use for staking turrets of all sorts of sizes.-Mike
