Hi. So my Mesa Nomad 55 2x12 is making strange noises, even when speakers are on mute. It seems like it's some kind of vibration, and it goes away completely if I apply some pressure to the top of the amp enclosure. Here is a video: https://youtu.be/ivLWd8UJVSs. Also tilting the amp backwards makes more noise. Does anyone have any ideas before I start unscrewing things? Any suggestions are appreciated.
Mesa Boogie Nomad 55 strange noise. Please help.
Originally posted by kute27 View PostHi. So my Mesa Nomad 55 2x12 is making strange noises, even when speakers are on mute. It seems like it's some kind of vibration, and it goes away completely if I apply some pressure to the top of the amp enclosure. Here is a video: https://youtu.be/ivLWd8UJVSs. Also tilting the amp backwards makes more noise. Does anyone have any ideas before I start unscrewing things? Any suggestions are appreciated.
Try tightening up the transformer mounting bolts, etc.
Originally posted by 52 Bill View PostI couldn't watch the video
All Youtube gave was:
"Content Warning
If the owner of this video has granted you access, please sign in.
This video is private."
I can't tell from your description if the noise is electrical or mechanical.
More importantly: are you talking about hearing this noise through your speakers? Or just "in general" (eg: there's a rattling noise)?Last edited by Audiotexan; 04-19-2015, 06:04 AM.Start simple...then go deep!
"EL84's are the bitches of guitar amp design." Chuck H
"How could they know back in 1980-whatever that there'd come a time when it was easier to find the wreck of the Titanic than find another SAD1024?" -Mark Hammer
Originally posted by kute27 View PostSorry about that, I fixed the video, shouldn't be private any more. Yeah, the noise is not coming through the speakers, so it's got to be mechanical vibrations I think.
It sounds like a "two-parter" to me.
1. there's a definite mechanical rattle...the higher pitched "criiiiink criiiiink"
2. along with (what sounds to my ear like) a 60 cycle hum (low pitched, constant humming)
My guess says that, it's coming through the speakers, and then through the chassis itself. And that that (approx. 60hz) hum is generating the "mechanical resonance" in the chassis.
What my train of thought is at the moment is:
Usually there's a metal sheet (shielding) installed on the underside of the top piece of cabinet wood. If there's a low freq. (60hz) gently sweeping through that sheet of metal, perhaps where it got bent slightly at some point (due to removal of the head, or reinstallation of the head)..then that might be the higher-pitched "criiiiink criiiiink". (now it's metal on metal sound, so it'd have to be the bent portion coming into contact with the metal chassis of the head).
The only other thing I could think of is on some of the amps from that era, they used a "full wrap tube cage" on the output tubes...and perhaps that's what's rattling at that certain point (again, giving the "criiiiink criiiiink").
Given that most Mesa reverb tanks I recall seeing are in the bottom of the cab in a combo...and that both noises stop when you press on the top of the cab...it could also be that you're "killing" the offending "60hz" source, thus negating the mechanical resonance that's being created as an after-effect. (So that doesn't necessarily mean you have a tank issue. Only that it's extremely sensitive to that relative vibration. But, it's still something I would keep on the back burner to check though IF you get the steady low frequency nailed down first.)
I would check both the upper sheet of shielding, as well as the cage (if there is one) -as those are the only things I can think of offhand that would react to pressure being applied where you did in the video. (However, that's assuming you were applying a fairly heavy amount of force. It looked like you were though IMO.)
As to the origin of the "60hz" (again, my "description")...possible guesses include:
1. the Primary (mains) transformer
2. bad cap in the primary psu section
3. bad solder joints to ground somewhere in the audio chain (aka a ground that's now "floating" and injecting noise)
Again, just shots in the dark for ideas/things to check, as I agree. This is *definitely* one of the strangest sounds that I've heard.
It'd be a LOT of help if you have a dummy load (ideally 8ohm/50w) to plug in, which would help verify whether it's coming through the speakers or not though!Start simple...then go deep!
