I'm going nuts trying to find a schematic for this powered monitor by KRK called a "Rokit powered 5 RPG2". Trying to fix it w/o one is near impossible, so does anyone know of a schematic for it? Please !!! thanks.
Anyone know of a schematic for this?
I don't have a schematic, but if it is the same KRK 5 powered speakers I have been seeing there are a few common problems. (KRK is Gibson I think) These problems are common to a lot of these powered speakers of several brands. The most common failure is the power supply filter caps opening up. They underrated the voltage spec because of size and space considerations. You have to be careful replacing them because of double sided boards and they use the cap leads for feed throughs. You also get bad connections because those boards can get rattled pretty good inside those cabs. Most of these monitors are bi amped. I have been able to source replacement speakers and tweeters for some via MCM, but if you do that you better do it in pairs. Working on them isn't really that difficult once you get past the globs of glue on the components, lol. They really aren't that complicated, just tedious and you have to dig in. Hope this helps.
Originally posted by olddawg View PostI don't have a schematic, but if it is the same KRK 5 powered speakers I have been seeing there are a few common problems. (KRK is Gibson I think) These problems are common to a lot of these powered speakers of several brands. The most common failure is the power supply filter caps opening up. They underrated the voltage spec because of size and space considerations. You have to be careful replacing them because of double sided boards and they use the cap leads for feed throughs. You also get bad connections because those boards can get rattled pretty good inside those cabs. Most of these monitors are bi amped. I have been able to source replacement speakers and tweeters for some via MCM, but if you do that you better do it in pairs. Working on them isn't really that difficult once you get past the globs of glue on the components, lol. They really aren't that complicated, just tedious and you have to dig in. Hope this helps.
Here is a similar one I have on file. Hope it helps.Attached FilesDrewline
When was the last time you did something for the first time?
Originally posted by Drewline View PostHere is a similar one I have on file. Hope it helps.
Here is the schematic of the RP5G2-A.
Unfortunately, quality of the picture is bad, but one can
see that the preamp is similar to the RP6G2.
Besides this monitors that KRK sells as the RP5G2 model,
may have different internal schematics (sub-types A, B, etc.).
In any case, I hope that this information can help you.
Good luck.Attached Files
Damn....the RPG6 one is clear, but it's a totally different circuit with a 15 pin chip in the LF section the 5 doesn't have. The other one is just too low quality to read anything. Maybe i can screen shoot it and do something in photoshop but not likely. This is just my luck ! Oh well, thanks for trying, appreciate it.
Originally posted by diydidi View PostWhat seems to be the problem you're having? I get a lot of these for repairs.
Originally posted by diydidi View PostGood on you!!
For a start, remove all the goop where you can. These have been known to become semi- conductive, and can cause all kinds of shit.
EDIT: if anyone has a schematic i'm still in need, as i can't read much of the one posted. It does help but for example, the must circuit has a open resistor and when replaced it works but with a loud hum which makes me think i need to check the rest of the mute circuit. (aside for the parts i WAS able to find and replace) But i can't because i can't tell what the part numbers are and tracing them is hard to impossible on this board. Right now it hums loudly when i turn it on then gradually lowers till it's about 1/4 as loud. Gotta be some other component that caused that resistor to open up. But i can't check or shotgun parts in that circut w/o knowing what they are.Last edited by daz; 04-29-2015, 10:09 PM.
Heres the schematic posted above, hard to read but at least the circuit configuration is viewable. http://music-electronics-forum.com/a...g2-scheme-.pdf
I have a question. The LF side works to amplify a signal, but theres a loud hum like a bad PSU cap would make. Looking at that schematic, can anyone tell me what component might be most suspicious if the hum goes away when i hit the right (low freq side) output (TDA2052) with a freeze? I suspected the LF output right away snd changed it twice to brand new ones and now have the original back in and they all do it, plus they all read right. So i don't think it's the 2052. But when i freezwe it the hum stops 1 What would you look at? I have shotgunned every electrolytic, checked every component against a known good board on the other monitor so it's gotta be something thats changing under load.
Originally posted by Jazz P Bass View PostMute the TDA2052 input pin (Pin 5) through a 22K R to ground.
If it still hums, then it's a power supply issue.
That can be resolved by measuring the Vac ripple right on the power pins. (Pin 2 V+/ Pin 4 V-)
It gets crazier....now i see the good one has some crackling sound and is a lot louder. This crap will be the death of me.Last edited by daz; 05-01-2015, 05:16 PM.
