Sounds like something that would be obvious to you guys so i figured i'd see what u think. Same as lat post, a powered monitor but this is the other one in the pair which just started doing this. I turn it on and i get a low hum that sounds like a PSU cap gone bad. But every second or so i hear a click like a relay kicking in but there is not relay. Each time it clicks the hum changes in volume. So every second it clicks and goes from the hum to a lower volume hum maybe 25% quieter then back again. If i freeze various parts it will at times change to where it clicks much faster, maybe 2-3 times a second and still changing the hum volume with each click.
"click"....hum...."click"....louder hum....repeat
What monitor is this?
"Same as lat post, a powered monitor?"
It sounds like the PSU is trying to start but then goes into protect.
Edit: this one maybe: http://music-electronics-forum.com/a...g2-scheme-.pdf
Well, i found something that isn't right but i'm not sure what could be causing it. The smaller of the 2 power supplies, the one on the bottom of the schematic above isn't working right. I tested the output and the + side is 24 VDC while the - side is 15 VDC. Problem is, i swapped the 2 caps and tested the 2k resistors and D101-104 all of which check out fine. Can something downstream from the supply cause that? If not, is it likely the transformer?
Thats screwy too, 10 and 18VDC. Is there any way it could NOT be the tranny? It's hard to see much on the schematic but the PSU i was able to figure out. After that tho it's hard if not impossible to determine whats what. Coming out of the tranny i get 18VAC on one side and 16 on the other.
EDIT: Ok, i was using the wrong ground. Using the middle pin of the PT connector i get about 20 VDC and 14 VDC on the lower and top supplies respectively, but now each supply's + and - are equal. But i don't even know what they should be.....maybe they are both supposed to be 15 VDC? Thats what i'm assuming and the lower one is therefore 5 VDC over maybe. I juts wish i could read that friggin schematic !
Also, i noticed the tranny has a voltage pinout and it reads correctly, or at least close. (1 VAC higher on both sides)Last edited by daz; 05-05-2015, 04:58 PM.
From what I can make out, the upper power supply (a Pass supply) is the + & - 15Vdc supply for the preamp opamps.
The 15 volt zeners hold the base of the transistors at 15 volts & therefore the transistors should 'pass' 15 volts.
The lower supply is the high voltage supply for the output stage.
I see 35V capacitors, so I would expect a higher voltage than 20V's.
Unless there is a connector that can be pulled from the PSU, you may have to lift the TDA2052 ic's to see if that supply comes up.
Originally posted by Jazz P Bass View PostFrom what I can make out, the upper power supply (a Pass supply) is the + & - 15Vdc supply for the preamp opamps.
edit: tried another TDA, no joy, same hum.Last edited by daz; 05-05-2015, 07:26 PM.
Originally posted by Jazz P Bass View PostVolt Meter.
Set it to read Volts AC.
I have seen high enough ripple that a 30 volt supply 'looks like' 20 volts.
It means the caps are bad.
DAz, my rule is never look for reasons not to check something. You may have swapped out the caps, but that doesn't mean there is not some cracked trace on the circuit board that effectively leaves the cap out of the circuit, for example.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostDAz, my rule is never look for reasons not to check something. You may have swapped out the caps, but that doesn't mean there is not some cracked trace on the circuit board that effectively leaves the cap out of the circuit, for example.
