Hi all,
This is my first post here and i hope someone can help. I have a Fender blues deville that has recently started to cut the signal in and out (just for a second or so at a time), the problem is worse as the amp is turned up higher or more specifically when driven harder at volume, for example if i run into the first channel, set the volume at between 4-6 and back off the guitar volume it'll generally be ok but as soon as i turn up the guitar volume say for a solo it'll start cutting the signal in and out. It seems to be a soft (but quick) drop in and out, not and instant drop off like you'd get from pulling your input jack in and out of the guitar socket.
I've re-tubed the 6L6's and the 3 12ax7's have all been A/B'd with other 12ax7's but it has made no difference.
Am i hearing a resisitor or cap breaking down on the output tubes perhaps???
FYI, the problem is the same with different guitar cables and different guitars.
Anyone come across this problem?
