Results 1 to 6 of 6
Thread: Ampeg SVT-II (non-pro) craps out after a few minutes
    New Member
    Aug 2015
    2
    0
    I love this amp and it sounds fantastic, for about 3 minutes and then it dies (sound gets squashed to nothing, amp keeps running). If I flip the Standby on and off it will keep working for a couple of minutes and then crap out again. I can plug into the Power Amp In input and it runs fine, so the problem must be in the preamp somewhere.
    As a side note that probably has nothing to do with the main problem, the best I can do with the bias controls for voltage between TP1 and TP2 is -0.035V, when the instructions say to get +/- 0.01V.
    Any ideas?
    edit: schematics found here: https://www.dropbox.com/sh/wdcfkjkly...RxNlrUfRa?dl=0
    Dec 2008
    Wernersville, PA
    12,921
    Received: 521/3
    Given: 275/0
    26
    Post a schematic?
    New Member
    Aug 2015
    2
    0
    Quote Originally Posted by Jazz P Bass View Post
    Post a schematic?
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    1,791
    Received: 647/1
    Given: 1,475/1
    11
    I'd take a look at C16...1uF electrolytic cap, from the cathode follower of the last preamp tube stage that goes out the ribbon cable header, passed thru the preamp output/power amp input jack. All the other coupling caps are film or maybe paper dielectric. If you have a scope, you could follow the signal thru the preamp and see where you begin to lose it. Could also be at the Graphic EQ, which follows this cap...but you do have an EQ in/out switch.
    C16.....10uF/16V. My SVT II schematic was a bit blurred, Jazz P Bass' s schematics cleared that up.
    Feb 2010
    11,739
    Received: 1,607/23
    Given: 4,112/11
    22
    That link is for the owners manual, not a schematic.
    Dec 2008
    Wernersville, PA
    12,921
    Received: 521/3
    Given: 275/0
    26
  1. Ampeg SVT-II Loud Hum
    By spforster in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-13-2014, 10:59 PM
  2. SLM AMPEG SVT-II Pro
    By shiner555 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-22-2014, 05:23 PM
  3. Need help with SVT II Pro
    By Roberto Lasco in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-19-2010, 06:47 PM
  4. Ampeg SVT II Pro - help needed
    Last Post: 01-08-2010, 05:12 PM
  5. Ampeg SVT-II Bias Procedure
    By 52 Bill in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-19-2008, 11:24 PM
Tags for this Thread
