Pioneer A-400 Volume pot troubles
  • Pioneer A-400 Volume pot troubles
    Hi
    I have a Pioneer A400 Hifi amp with a broken pot, Was dropped
    The pot is a 100k concentric type But with 4 solder lugs per pot. I have spoken to a supplier who are pioneer dealers here in the uk but the pot is NLA
    I have check Ebay etc. I can find nothing
    A-300_400-amp.pdf this is the only copy i have of the map
    The marking on the board show the layout for a normal pot, So ive soldered one in on the volume and the balance. Not working correctly.
    If you see the picture there is a 4th solder lug.
    Can anyone assist on possibly making a mod so this will work ? Would be happy to just have a volume pot and hard wire the balance. Do you know where i can get a 4 pin pot that i can use
    Bassman
    Look at your photo, the leg on the left is a tap up near the top of the resistive stripe. That is a loudness tap. The three legs on the right are like any pot.
      Thanks enzo. I’ve fitted a standard pot in the place but it does not work correctly. The amp was working correctly with original pot but kept cutting out. on inspection i found a hairline crack though the base of pot
      Is there anything i can do with this. Can you get pots like these? I have checked all the suppliers in the uk and can't seem to see one, Not sure if they have a name
ID:	839189 this is the original pot that is NLA
      Bassman
        Hi Bassman
        I'm guessing when you say you have checked pioneer dealers you have checked with Charles hyde and son ( CHS) ? They are listing the pot on there website
        BBB
          Yes mate CHS checked with pioneer both 100k and 50k versions NLA
          Bassman
            Many thanks for all your help. Ive found one. as used pop from a local hifi repairer.. job finished
