.How much tolex will you need to covered cabinet
  • .How much tolex will you need to covered cabinet
    Since most guitar cabinets are only about 10 or 12 inches deep the 18" width tolex should give you enough to cover the depth of the cabinet and to wrap around the edges. Measure around your cabinet (top, bottom, left and right sides) then order enough to wrap all the way around in one piece. Don't forget to order enough for the back panel if your cabinet has one. It is your responsibility to measure and order what you need, but here's a general rule of thumb.
    *Most 1x10 or 1x12 speaker cabinets or combo amps will require 2 yds of 18" wide material -don't forget to include enough for your back panel if applicable.
    *Most 2x12 combos will require 3 yds. of 18" wide material. 24"x36" piece for back panel.
    *Most 4x12 cabinets will require 4 yds of 18" wide material, 36"x36" piece for back panel
    Tube guitar amp, hand made effect pedal , power attenuator , Vinyl and tweed tolex, speaker grill KLDguitar.com
    This belongs here:
    Plug Your Product/Service
    We have a place to plug your products and it's not here.
      ^^^^^ SPAM ^^^^^
      ^^^^^ SPAM ^^^^^
      ^^^^^ SPAM ^^^^^
      ^^^^^ SPAM ^^^^^
      ^^^^^ SPAM ^^^^^
      Can some moderator either move this post to where it belongs, remove the commercial links or both?
      To add insult to injury, this is not even one of the dubious "contributions" by KLD, cut and pasted from R.G. Keen's or Steve Ahola's sites but text straight from his own ad !!!!!!!!!!!!!
      Thanks.
