I have a Marshall Super 100 re-issue in for a hum issue that turns out to have a dead KT66. The other three seem OKay, the are Russian Gold Lion brand. I ordered up a new set of JJ KT66s, but the bases are so large, they won't fit into the spring clips, and I am not going to mod this amp to accommodate this. These sets are expensive at about $150/quad. Does anyone have any experience with other brands of KT66? There doesn't seem to be many choices. And also, any opinions on just replacing the dead one? The ones I have are from the Tube Store, and have their rating system of 39 on them, whatever that means. Would you trust just ordering another 39 and see if it actually matches?
New KT66 opinions
I've had JJ KT66s fail on me and at least one Gold Lion, maybe two. Tung Sols and Valve Arts have lasted for me. Some people say the TS are more 6L6 sounding, kind of KT66 with their own thing, I really liked them in my JTM45.
Is the Super 100 one of the reissues with the really high screen and plate voltages? That might be a factor, seems like I read it was either with that one or the Hendrix JTM45-100 reissue that people were having issues with modern tubes not being able to handle the voltages...
Originally posted by Randall View PostThe ones I have are from the Tube Store, and have their rating system of 39 on them, whatever that means. Would you trust just ordering another 39 and see if it actually matches?This isn't the future I signed up for.
Yes, you can order just another 39 from The Tube Store and it will match your remaining good tube.
One caveat you should know about is the metal base on the Tung Sol KT66 reissue. The metal base is tied to pin 1 and will short the bias voltage to the bear claw tube retainer. If you do decide to go with the Tung Sol KT66, you will need to change the retainers to the spring type.
http://ztalk.proboards.com/thread/27...w-tung-sol-66s
The Tung Sol "KT66s" only draw 900 mA while to my knowledge all other modern "KT66" draw 1300 mA.
I have had an inordinate number of failures with ALL Gold Lion tubes, but their KT66 seems even more fragile than any other I've tried. The Valve Arts are solid as are the Ruby and TADs - all three just test and rebrand tubes but don't actually manufacture them. The JJs sound good, but I've experienced excessive tube rattle from far too many of those to recommend them.
I would recommend these, in this order:
1) Ruby
2) TAD
3) Valve Art
4) Tung Sol
None of these are true KT66, of course.
The plate voltage is about 545 v, that was with two tubes installed. They are drawing from 49.8 mA to 52.7 mA.I spo 's whatke with a tech at Tube Store (very helpful), and he thought since these are still fairly new with not much use, and still pretty well matched I should have a pretty good chance of getting a new one to match. So that's what I did.
Let's see how long this $52 single tube takes to ship from Canada to Southwest Florida.It's weird, because it WAS working fine.....
Originally posted by Tone Meister View PostWhich KT66s are you using in your JTM45 Leo_Gnardo?
545V plate Randall, and close to that on screen grids, with 50 mA, I think your friend at the tube sales desk is whistling in the graveyard. That's IMO a stretch for '66's. Sometime your customer should try a set of KT88, I really think that's a better choice. I've used EH - some problem tubes - and JJ - so far no problems. The hi fi crowd seem to adore the premium priced GEC/Genalex line marketed by New Sensor aka Sovtek/ElectroHarmonix.
I'd mention KT77 too but I find they work well in some amps & not others, it's a matter of "do you like what they sound like when heavily clipped". Not for every situation but can recommend for hifi amps, where I've used JJ successfully in Dynaco Stereo 70, MkII and MkIII. .This isn't the future I signed up for.
Originally posted by Randall View PostLooks like cooling off the bias on this one is in order. Every amp this customer has brought has been way hot.
