Results 1 to 21 of 21
Thread: Der EE DE-5000 Handheld LCR meter - short review
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    Recently, Redhouse lent me his brand-new DE-5000 Handheld LCR meter for evaluation of its suitability for measuring guitar pickups, and asked me to present the results on the forum.
    The worry was, based on the published specifications, that the DE-5000 might misbehave wildly when presented with such a lossy inductor as a pickup, as happens with many models of handheld LCR meter. This did not turn out to be a problem, with both units showing gradually degrading accuracy when the dissipation factor (Rac divided by inductive reactance) exceeded about 20.
    This kind of gradual decline in accuracy is expected because the inductance signal becomes smaller and smaller compared to the AC resistance signal as the dissipation factor rises.
    When the dissipation factor exceeded 20, the Extech lost accuracy faster than the DE-5000 as the factor increased; this is probably due to the fact that my Extech was made ten years ago, and technology has marched on in the meantime. Current Extechs may be better. However, real pickups have far lower dissipation factors at 1 KHz, so this is not a problem in practice.
    When measuring a handful of pickups with both instruments, the instrument readings agreed to within 1%, the stated accuracy of the instruments.
    The bottom line is that for measuring guitar pickups, the DE-5000 is just as good as the Extech 380193 that has been our standard since 2004.
    Summary of differences:
    Extech measures L, C, and Rac, parallel and serial model, at 120 Hz or 1 KHz. There is only autoranging on parameter value; selection L, C, or R et al are all manual.
    DE-5000 measures L, C, Rac, and Rdc, parallel and serial model, at 100 Hz, 120 Hz, 1 KHz, 10 KHz, and 100 KHz. Ranging is almost completely automatic, which while convenient with near-ideal LCR components (like surface-mount components), is a nuisance with pickups (which are non-ideal inductors). In particular, the DE-5000 will switch from serial model to parallel model (is the R in series with the L, or in parallel with the L) above a certain dissipation level, causing gross errors when used on a pickup. However, the DE-5000 does allow one to manually set the model to serial, allowing pickups to be measured accurately.
    Note that for reasons related to the properties of LCR circuits and unrelated to the specific LCR meter in use, the 10 KHz and 100 KHz test frequencies are not useful for measuring the inductance of guitar pickups.
    Neither instrument will measure voltages or currents. The Extech feels more ruggedly built, being encased in a thick rubber boot and weighing 20% more than the DE-5000, but the DE-5000 is rugged enough for shop use.
    The DE-5000 is roughly half the cost of an Extech 380193. Both units are made in Taiwan.
    Supporting Member
    Sep 2007
    3,171
    Received: 198/0
    17
    How do the measurements compare at 120 Hz, where no pickup has significant eddy current losses?
    (The DE-5000 should not confused at that frequency, another possible reason for using it.)
    Supporting Member
    PDX
    3,333
    Received: 64/0
    Given: 35/0
    19
    Red house, thanks for taking one for the team and thanks to Joe for checking it out.
    Seems to cost about $95 New Der EE de 5000 Handheld LCR Meter w TL 22 High Accuracy Measurement | eBay
    Feb 2010
    12,643
    Received: 2,186/24
    Given: 5,512/11
    24
    It's useless without attachments so get the ones you need. TL21 is alligator clips, TL22 is smd tweezers.
    Don't be a fool and get the cheap version with no attachments then have to pay shipping again for probes like I did .
    You can not use any kind of regular probes with it.
    (edit: above statement is erroneous, unit can be used for most purposes with regular probes)
    Supporting Member salvarsan's Avatar
    Jan 2008
    The pines country.
    1,102
    Received: 17/0
    Given: 10/1
    15
    A few searches suggest that the Der EE DE-5000 is the OEM version of the discontinued IET Labs DE-5000.
    IET still archives the DE-5000 manual.
    The IR-to-usb module is a ~$60 option for thems that want data logging and are comfortable using Labview. The data report period is 1.2 seconds, about the same as the Extech.
    Diyaudio.com forum has a teardown, notes that the LCR and display functions reside in two chips from Cyrustek.
    When they close the gun shops, I'll know that the Texas gov't is taking the pandemic seriously.
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    Quote Originally Posted by Mike Sulzer View Post
    They compare to within a fraction of 1%, even using a 960 mH air coil that I built for tests back in 2005.
    By the way, I also tested a humbucker at 120 Hz, and there is significant eddy-current loss.
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    Bingo. The Der EE DE-5000 looks exactly like the IET DE-5000, and the manuals are basically the same.
    I bet Der EE was IET's manufacturer, now permitted to sell direct now that IET has discontinued the unit.
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    While I agree that it's best to get the attachments, it is not true that the DE-5000 is otherwise useless. Standard 1/8" (4mm) banana plugs will fit just fine.
    Supporting Member
    Sep 2007
    3,171
    Received: 198/0
    17
    Quote Originally Posted by Joe Gwinn View Post
    That is very interesting. The losses at 1 KHz must be much larger. Do you have the numbers, and do you know the core material?
    Feb 2010
    12,643
    Received: 2,186/24
    Given: 5,512/11
    24
    Yes, implying it was totally useless was too strong a statement, sorry.
    I thought the kelvin type shielding would make a substantial difference for your purposes, but maybe it's not so substantial?
    I guess it will calibrate without the special attachments?
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    At 1 KHz: 3.861 H and 11.11 Kohm ac
    At 120 Hz: 4.302 H and 7.57 Kohm ac
    At DC: 7.477 Kohm (measured with a 6.5 digit DMM)
    The unit is a traditional humbucker, with slug poles on one side, screw poles (threaded into a steel bar), and an alnico bar between the slugs and the steel bar. There are no names or numbers on the unit.
    With an air-core coil, Rac equals Rdc pretty closely. One can verify the effect of the nearby metal by measuring the coils on bobbins before assembly of the humbucker.
  12. #12
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    A four-wire (kelvin) connection is used to cancel out the contact and lead impedances, so that the component value may be accurately determined.
    For pickups, lead and contact impedances are swamped by the pickup, the kelvin connection is not needed, and so ordinary banana plugs (which will short the two halves in each jack together) are OK.
    https://en.wikipedia.org/wiki/Four-terminal_sensing
  13. #13
    Supporting Member
    Sep 2007
    3,171
    Received: 198/0
    17
    You are right, it is significant in the sense of a repeatable consistent effect. That ratio of dc/ac resistance at 120 HZ is at the top end of what I measure normally. The "not significant" I was thinking of is "not large enough significantly upset the measurement of the inductance (without the effect of eddy currents)". As your measurements show, the apparent inductance at 1 KHz is below that at 120 Hz, and this is always true, I think. The typical behavior is that as frequency rises from near zero, the apparent inductance rises just slightly above the true low frequency limit before falling below at somewhat below 1 KHz. The measurement at 120 is usually close enough to the limit for practical work.
  14. #14
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    It's certainly true that comparing measurements made at 1 KHz and at 120 Hz will allow one to estimate the magnitude of eddy-current loading, even if 120 Hz still has some eddy-current loading.
    Physically, the better metric of eddy-current loading is the difference Rac (taken at various test frequencies) minus Rdc (the copper wire). This excess resistance (of Rac compared to Rdc) is largely the eddy-current effect, exclusive of everything else.
    The behavior of inductance as a function of test frequency is dominated by the physical shape of the metal mass causing the eddy-current loading. If the metal is laminated (or ground to dust in epoxy), the loading is reduced and the inductance rises.
    The electrical resistivity and magnetic permeability of the metal also matters.
  15. #15
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    Principles of Operation of Extech and Der EE and IET LCR Meters
    Given the clue that the DE-5000 was a discontinued IET product, in turn having originally been a GenRad (General Radio) product, I did a little digging and uncovered the founding patents:
    US 4,196,475 and 4,181,949, both to Henry P Hall of Concord MA.
    Edit: The better explanation in in US 4,342,089.
    Benchtop LCR meters from GenRad are somewhat more complex, but the basic principle is the same. The block diagrams are given in the operating manuals on the benchtop units currently sold by IET.
    For instance IET model 1693 (see chapter 4): http://www.ietlabs.com/pdf/Manuals/1693_im.pdf
  16. #16
    Jun 2014
    Melbourne Australia
    206
    6
    I have had my Der -EE for some time now and am happy with its performance
    i have used it with banana pugs and test clips from the beginning and the only issue it had given is if you use longer leads it will not calibrate. i do suggest leads no longer than 6" for this reason
  17. #17
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    I've been reading around and found one thing to beware of:
    If you install the 9-v battery backwards even once for an instant, you can destroy the instrument, at least on units bought a year ago.
    See reply #11 in Der EE DE-5000 Unboxing and Teardown - Page 1
    The problem may have been fixed by a board revision, or not. A good question for the seller to answer.
    Anyway, a bit of care is in order.
  18. #18
    Senior Member RedHouse's Avatar
    Jun 2006
    Pacific NW - USA
    1,780
    Received: 4/0
    16
    Thanks for doing the work Joe, we all appreciate it.
  19. #19
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    Quote Originally Posted by RedHouse View Post
    Welcome, and thanks to you for suggesting this test.
  20. #20
    May 2013
    Monterey Bay
    141
    8
    Thanks for the overview.
    I have a Der EE DE-5000 (use with reg. banana plugs) as well as an Extech 380193 and find them consistently comparable. I've been meaning to do a thread on this for awhile, glad you did!
  21. #21
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    Quote Originally Posted by mr fab View Post
    i have used [the DE-5000] with banana pugs and test clips from the beginning and the only issue it had given is if you use longer leads it will not calibrate. i do suggest leads no longer than 6" for this reason
    The short calibration should work so long as the total lead resistance does not exceed 1.1 ohms. Was there a bad connection?
  1. the source for DE-5000 LCR meters on ebay
    By dai h. in forum Music Electronics
    Last Post: 06-20-2014, 04:30 AM
  2. LCR METER what do i need ?
    By copperheadroads in forum Pickup Makers
    Last Post: 07-01-2010, 12:32 PM
  3. handheld LCR meter more accurate on battery power?
    Last Post: 12-29-2009, 11:45 AM
  4. LCR meter at 10KHz
    By StarryNight in forum Pickup Makers
    Last Post: 03-10-2009, 06:42 PM
  5. Determining a short with an LCR meter
    By kevinT in forum Pickup Makers
    Last Post: 12-12-2007, 02:46 PM
