Convert Your Fender Super Champ XD (others?) to ALL-ANALOG
  • Convert Your Fender Super Champ XD (others?) to ALL-ANALOG
    Here is a simple (no circuit board removal) and cheap (shouldn't cost you over $5 in parts) way to produce an analog-only Fender amp from one that contains a digital (DSP) board. You will lose all effects and end up with VOLUME and BRIGHTNESS controls, much like the original amps. The project requires that the power supply, and all of your tubes are working - the DSP board itself can be failed. It is expected that you can add all the effects you want with external pedal boards. Here is a link to the instructions, which includes the parts list and a frequency graph of what to expect after the mod:
    http://brasherweb.com/techfiles/Fend...bypass_mod.pdf
    If you have questions, you can email me (address is in the doc). Good Luck!
