We are assuming that there is no input signal applied when you made the measurements "at idle." The concern is the much higher than normal AC ripple on the screens and grids. Unless the AC frequency is ultrasonic I would expect the amp to have a loud hum at idle. Especially with 1.5VAC on the grid.
More fun with scope image interpretation
Originally posted by nsubulysses View PostInput signal voltage is about 300mV pk-pk for 1KHz and 100Hz.
Originally posted by nsubulysses View PostI'll try my other signal gen tonight when I get back to it too just in case. I don't htink it's that though, since this big modulation is only becoming visible in the output section.
Looking at the vids I see what looks like signal doubling. It's the paired and warbling lines at mid frequencies and the traveling node along the waveform at lower frequencies. Like the beating of two notes that are out of tune causing a ring modulator effect. I can't figure how the power amp would do this by itself. Hum was mentioned. This doubled signal could be a sum/difference overtone from excessive ripple in the signal chain.Last edited by Chuck H; 09-17-2015, 11:08 AM."Take two placebos, works twice as well." Enzo
[QUOTE=Chuck H;396858]Originally posted by nsubulysses View Post...Looking at the vids I see what looks like signal doubling. It's the paired and warbling lines at mid frequencies and the traveling node along the waveform at lower frequencies. Like the beating of two notes that are out of tune causing a ring modulator effect. I can't figure how the power amp would do this by itself. Hum was mentioned. This doubled signal could be a sum/difference overtone from excessive ripple in the signal chain.
Cheers,
Tom
It's all good y'all. thank you for your input. As usual many people were right on.
I traced AC around and replaced C8, D13 and D11. Slightly shotgun but it's kind of a pain to pull the tubes and pull the board over and over. I have a very stable signal now and fractions of a VAC on grids. Have never listened to this amp through a speaker yet but I bet when I do tomorrow it will sound alright.
VAC RMS is misleading because I had it plugged into 8 ohm load at the time and the head only goes as high as 4 ohms.
Sorry this new scope is such an eyesore compared to the old analog ones but still fun to post vids and hear the old masters comment
Originally posted by nsubulysses View PostIt's all good y'all. thank you for your input. As usual many people were right on.
JMFJuan Manuel Fahey
What is the shake on the clipped portion of the wave about? I've never seen that before. Could it be an artifact of another problem that was exacerbating the issue you already repaired?"Take two placebos, works twice as well." Enzo
Chuck that is power supply ripple. At full power output the signal gets a little modulated because the power supply is being taxed to the max
Check this -- http://music-electronics-forum.com/t37757/
Originally posted by nsubulysses View PostChuck that is power supply ripple. At full power output the signal gets a little modulated because the power supply is being taxed to the max
Check this -- http://music-electronics-forum.com/t37757/"Take two placebos, works twice as well." Enzo
Yes.
And the other way, which happened here and in the thread posted by nsubulysses, is to have a test frequency which is a multiple of ripple frequency.
The wiggle is the beat (difference in this case) between both, or between test signal and ripple exact multiple.
It happens all the time when clipping a power amp, because there you *always* have important ripple , not the case in a preamp, even including the PI in some cases, because those few mA are very easy to filter, while power amps need from half to a full Amp if tube and up to tens of Amperes in SS .
Now you can't physically see wiggling above, say, 15/20 Hz , eyes are slow (thanks God or we wouldn't have Cinema,TV, etc.) so in practice you must be within, say, 5Hz to see it.
In nsubulysses' thread test frequency was nominal 600Hz, varying between 599 and 601, while line frequency is either 50/60Hz, ripple 100/120Hz.
Probably by chance he chose "600Hz" which is an exact multiple of all of 50/60/100/120 Hz ; if he had tested with, say, 440Hz wiggle would still have existed, but impossible to see.
In this case wiggle frequency was 1 or 2 Hz, a fast tremolo (literally) but still visible.
In any other case, ripple is visible, specially a thigh frequencies, if you slow scope sweep down long enough to see the ripple peaks themselves, riding the test signal, as Tom Philips suggested.Juan Manuel Fahey
Most of the more expensive analog oscilloscopes have a control called Holdoff. This adjusts the time between the end of a horizontal sweep and when the trigger is enabled for the next sweep. If it is adjusted while viewing a 600Hz waveform, a place can be found where the waveform will sync up with the line frequency and the waveform will start wiggling up and down showing the ripple. If the 600Hz is exactly in sync with the line frequency, the wiggling will stop and you will be able to see where each cycle is clipped slightly different.Last edited by loudthud; 09-18-2015, 07:35 PM.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostMost of the more expensive analog oscilloscopes have a control called Holdoff. This adjusts the time between the end of a horizontal sweep and when the trigger is enabled for the next sweep. If it is adjusted while viewing a 600Hz waveform, a place can be found where the waveform will sync up with the line frequency and the waveform will start wiggling up and down showing the ripple. If the 600Hz is exactly in sync with the line frequency, the wiggling will stop and you will be able to see where each cycle is clipped slightly different.Experience is something you get, just after you really needed it.
