Results 1 to 17 of 17
Thread: Gibson G70
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    Gibson G70
    Hey Folks ! Anyone know where I can find a Gibson G70 schematic/layout ?
    Thanks !
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,883/23
    Given: 1,463/35
    27
    Here's the annotated power amp.
    Can search for the preamp if you need it.
    1 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,134
    Received: 1,881/7
    55
    Um... shouldn't Q6 be an NPN?
    And are they not darlingtons?
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    Thanks Juan ! I'll take all I can find. I'm coming up empty.
    Oct 2007
    11,753
    Received: 1,883/23
    Given: 1,463/35
    27
    Hey !!! this is the official GIBSON schematic!!!!!!
    Don't tell me you know more than them !!!!
    Just answer: did Eric Clapton and Jimi Page use a Gibson guitar or an Enzo guitar , huh ?????? <--typical TGP/MyLP/Harmony Central/etc. argument
    Q3 , Q4 , and Q6 are NPN .
    MJE1102/1092 are Darlingtons (notice the 1000/1200mV BE bias I expect to find there) and to boot are way underpowered for a 70W amp : 5A max current , "70W" , in that tiny smaller than TO220 case, like typical Peavey drivers .
    They were notoriously unreliable (I wonder why ) and upgraded 3 times.
    MJE1102 pdf, MJE1102 description, MJE1102 datasheets, MJE1102 view ::: ALLDATASHEET :::
    I suggest TIP142/147 there, but pinout will no match, check both datasheets.
    I posted what I found first, there's an old thread here, also search for other Gibson amps, there's one called something like G50/60/80 somewhere in MEF, all preamps were basically the same.
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    Thanks for the info. I'm trying to find out what the values of the two big can caps are ?
    Oct 2007
    11,753
    Received: 1,883/23
    Given: 1,463/35
    27
    Here's a Gibson G50/60/70/80 schematic, obviously a very different version under the same name.
    It's in SSGuitar
    Login
    Gibson G-80
    As said before, they kept replacing them under warranty, this one is a little stronger, used TIP33 powerhouse transistors .
    Don't know which you actually have, a Darlington or a Discrete one?
    Post a couple pictures.
    For good measure, I'm adding G10/20/30 too so you have all the family.
    By the way, what are you trying to fix?
    PD: that said, yours might be *completely* unrelated
    EDIT: that's the easiest part: 2200x50V or 4700x50V .
    Tne earliest ones used large chassis clamp mounted electrolytics, modern ones will be radials 1/2 (or less) the size, solder their legs where approppriate.
    Unless you want to keep the Mojo and insist on $65 a piece NOS Electrolytics.
    If so, I also have a couple bridges you might interested in, you give me U$5000 in cash, in small denomination unmarked bills and then you can charge toll to cars using it, how's that?
    Attached Files Attached Files
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    It's in SSGuitar
    Login
    Gibson G-80
    Thanks Juan ,I'm good on bridges lol
    I'll get some pictures asap.
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    Here are a couple of chassis shots.
ID:	35957   Click image for larger version.
    Oct 2007
    11,753
    Received: 1,883/23
    Given: 1,463/35
    27
    Ok, then you seem to have the same power amp as the original "orphan/annotated" schematic, because on ther right edge of the first picture I see 2 x TO92 transistors (Q3/Q4?) , a TO220 one (Q5?) , 2 puny small plastic transistors (TO126 case? ... ridiculous) 2 bias diodes clamped to chassis/heatsink and the very old style bias trimmer.
    I'd replace the power transistors with TIP142/147 without even checking them, go figure.
    Pay attention to pinout which does NOT match.
    The preamp might match though:
    2 DIP ICs
    2 trimmer pots (reverb & tremolo)
    5 TO92 transistors
    1 heatshrinked *lamp*/LDR tremolo roach.
    Oh well.
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    2 DIP ICs
    5 TO92 transistors
    Oh well.
    Thanks Juan ! I don't have this amp in hand yet. It belongs to my cousin ,and I'm waiting for him to bring it to me. We'll get a parts list together also.
  12. #12
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    2 DIP ICs
    5 TO92 transistors
    Oh well.
    I finally have this amp in hand. Looks like someone tried to mod? ,or repair at one time. Added caps ? Some places you can see were disconnected from the board ,and hardwired. May have to strip all the mods? ,and start over.
ID:	36190   Click image for larger version.
ID:	36189   Click image for larger version.
ID:	36191   Click image for larger version.
ID:	36192   Click image for larger version.
ID:	36193   Click image for larger version.
ID:	36194   Click image for larger version.
  13. #13
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    Could Admin please move this ?
    Could this thread be moved to repair ,and troubleshooting , or should I start another for repair help ?
    Thanks !
  14. #14
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,398
    Received: 1,417/21
    Given: 1,205/0
    14
    Quote Originally Posted by gtrplayr1976 View Post
    Thanks !
    No admin here but you could start a new thread at the appropriate spot R&T, & put a link back to this thread for e-z reference. Costs nothin' but a minute of your time.
  15. #15
    Supporting Member
    May 2010
    WV
    962
    Received: 14/0
    Given: 105/0
    10
    Thanks Leo_Gnardo lol
  16. #16
    Dec 2008
    Wernersville, PA
    12,940
    Received: 533/3
    Given: 288/0
    26
    Thank you for the schematic J M Fayhey!!!
    I could not find this oddball version anywhere.
    Kudos to MEF.
    I got one of these jewels in with the MJE1102/ 1092 transistors installed.
    Of coarse they where blown.
    I have reattached the schematic: Click image for larger version.
  17. #17
    Dec 2008
    Wernersville, PA
    12,940
    Received: 533/3
    Given: 288/0
    26
    Here is the schematic with the correct orientation of Q6. (it is a NPN transistor)
    Edit: The LTP (Q3 & Q4) where drawn as PNPs when in fact they are NPN transistors.
    G70 Power Amp.pdf
  1. Gibson Falcon: Does this look right?
    By Jonny toetags in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-12-2014, 10:43 PM
  2. Gibson G 30
    By gbono in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-29-2012, 07:32 AM
  3. Gibson-like project
    By dkevin in forum Vintage Amps
    Last Post: 07-23-2009, 06:03 PM
  4. Gibson GA42RVT
    By EFK in forum Theory & Design
    Last Post: 08-24-2008, 06:16 PM
