Results 1 to 26 of 26
Thread: Two tone stacks parallel after cathode follower
    Oct 2009
    102
    11
    I guess it's possible to connect parallel e.g. two classic Marshall tone stacks after cathode follower and use relay switching only on outputs of stacks (tone stacks for crunch and lead channel) and it will work, but:
    - isn't it too high load for cathode follower ?
    - won't affect changes first stack tone controls frequency response / sound on output second tone stack ?
    - doesn't two stacks parallel change operational point of follower and so signal harmonics / shape of overdrive signal instead of usually only one tone stack ?
    Apr 2015
    Minneapolis, MN
    333
    Given: 1/0
    5
    You could use a double pole relay to switch both the input and outputs to isolate the front and back end of the stacks from each other. This way there will be no interaction of the two. I hope I understood your intention when suggesting this. Also, the cathode follower will drive a wide variety of stacks, so I wouldn't worry too much about the difference in them unless they have a very different input impedance.
    Turn it up so that everything is louder than everything else.
    Jun 2006
    288
    Received: 16/0
    Given: 2/0
    14
    Checkout the Marshall JVM410. Series resistor between the treble viper and volume for each channel, then channel mute and a series mix resistor.
    No need to switch on the input side of the tone stack.
    EDIT: Schematics here: http://forum.metroamp.com/viewtopic.php?f=25&t=21932
    Oct 2009
    102
    11
    Of course, double pole relay is standard circuit to disable any interaction between two tone stacks, but I would like to know if possible to do it only with one pole relay, two stacks parallel, without some major difference in sound and circuit operation.
    Oct 2009
    102
    11
    Thanks, I have this schematic, it's clear.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    Short answer: the cathode follower *easily* drives 2 regular Marshall tone stacks, just switch between stack outputs or if you wish, between following volume controls if you have them there.
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    But there may be still significant interaction between the two stacks. It would be wise (and not too difficult) to check and possibly optimize Your intended setup with LTSpice.
    Supporting Member
    Sep 2007
    3,157
    Received: 191/0
    17
    Quote Originally Posted by bea View Post
    I have to second this. Cathode followers have low impedance when they operate linearly, but halving the impedance of the load decreases the linear voltage swing by a factor of two. (You only have so much current available)
    If a stage of gain operating into a cathode follower is operating linearly, then the low impedance of the CF (order of 1/gm) keeps interaction low when driving two stacks. But if you drive two stacks instead of one when one is intended, it would reach its linear limit sooner, and then you have interaction since you lose the low impedance.
    Also, if you over drive the stage of gain driving the cathode follower, then the follower does not necessarily operate linearly, and then it does not have a low impedance output and you lose the isolation between the stacks.
    I think it is better to switch at the input unless you can be sure neither of these things happens.
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    And each tone stack sees the impedances of the other one. The system is hardly overseeable.
    An alternative to a switch in front of the stacks might be one or two JFET source followers after the cathode follower. With a common input resistance somehow mimicking the load of one single tone stack. Then You should be able to safely switch with a single switch.
    Dec 2009
    Devon, UK
    3,632
    Received: 821/1
    Given: 632/1
    14
    Another strategy is to swap the CF cathode resistor for a transistor or MOSFET based constant current source of around 2 to 3mA. Very inexpensive and drives capacitive loads very well.
    Supporting Member
    Sep 2007
    3,157
    Received: 191/0
    17
    The two tone stacks do not see each other as long as the impedance of the cathode flower is low. You do not want to use solid state with such a large voltage swing
  12. #12
    Supporting Member
    Sep 2007
    3,157
    Received: 191/0
    17
    Quote Originally Posted by nickb View Post
    The current source is a high impedance; it cannot help here.
  13. #13
    Oct 2007
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    Agree with last two and not much with earlier ones, but learnt not to argue against Deeply Established Beliefs
  14. #14
    Supporting Member
    Sep 2007
    3,157
    Received: 191/0
    17
    OK, but I would argue for the difference between a low dynamic impedance and the ability to drive a low impedance load to near the power supply rail. The extreme example is an op amp follower, which might have a few micro ohms output impedance at 100 Hz, but lack the ability to drive a 500 ohm resistor to near the power supply rails. This is not a DEB, but rather a DET.
  15. #15
    Near Dallas Texas
    3,555
    Received: 246/0
    Given: 125/1
    18
    If you watch the output of the common 12AX7 cathode follower when the signal is a big square wave you can see where positive to negative transitions are slewing as fast as the 100K can pull down. The tube cuts off until the 100K can pull the tone stack low enough to catch up with the cathode follower's input. This changes as you adjust Bass and Mid pots so there will be some interaction between two tone stacks if signals are large. One way around this is to use a cathode follower with at stronger current source. Perhaps a 12AU7 with 22K load.
  16. #16
    Jun 2006
    288
    Received: 16/0
    Given: 2/0
    14
    If Marshall can make it work with 3 tone stacks plus the clean channel volume control in parallel from a regular 12AX7 cathode follower, it obviously works with two tone stacks.
    The key is the series resistor (39k) between the treble viper and volume to avoid interaction with the channel mute switching.
  17. #17
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    I was simply skeptical that the impedance of a 12AX7 as a cathode follower would be really low enough. Therefore my suggestion to spice before building.
    Another possibility to consider might be to check wether an ECC832 could be used instead (i.e. if the pinout matches so that the 12AU7 system of the tube would be in the position of the cathode follower.)
    Or if an ECC81 which combines high and low output impedance would work better.
    But always: spice before taking the iron.
  18. #18
    Supporting Member
    Staffordshire UK
    3,822
    Received: 562/1
    Given: 486/2
    18
    I think that the waveform at the output of an overdriven dc cathode follower will be affected by adding more tone stacks to load it, in the same way that it is significantly affected by adding the first tone stack (compared to its unloaded output); the cathode follower's ability to sink/source current with large signals being the issue, rather than its small signal output impedance.
    But it will very likely sound fine and not be a problem, as per the Marshall 410.
    Whereas a different tube type for the cathode follower may be more likely to result in a difference that the user may notice.
  19. #19
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    But the Marshall 410 was just an example. The question was generic.
  20. #20
    Mar 2007
    Philadelphia suburbs
    491
    13
    We would never want to do anything in a guitar amp that makes it perform in a non-linear fashion; that never works out well. ;p
    To paraphrase my main man Jim Croce, "If it sounds good do it. If it sounds really good, do it twice."
    (None of this is aimed at you PDF64, just seemed like a good place as any to interject).
  21. #21
    Aug 2006
    Lancashire
    649
    Received: 16/0
    14
    Although a 12AX7 CF would probably drive two Marshall tone stack simultaneously without problems, I would use Fender tone stacks (but tweaked for a similar frequency response), i.e. higher impedance.
  22. #22
    Cheshire, UK
    2,291
    Received: 593/4
    Given: 308/0
    16
    Why not use two CFs, one for each tonestack?
  23. #23
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    What would You do with the remaining triode?
  24. #24
    Dec 2009
    Devon, UK
    3,632
    Received: 821/1
    Given: 632/1
    14
    Seems we are trying to discuss in a data vacuum so I've got some info to add fuel to the fire
    I've done three things and I'm making the assumption that only one half of 12AX7 is available.
    1. Determine the input impedance of a Marshall tone stack. I'm calling this nominally 50K ohms - see the top chart below.
    2. Charted the output impedance of a 12AX7 with plate to cathode voltage of 150V vs plate current. On the second chart below the output impedance is 420 ohms with a plate current of 1.5mA and 350 ohms with 2.5mA. Gm goes up with plate current.
    3. Set up four sample cathode followers. All are fed with 140Vpp from with a source impedance of 50K. All are loaded with two tone stacks represented as 25K in series with 1uf ( for DC blocking). The supply is 300V and the source offset is 150V. See the bottom chart.
      1. Cathode follower with 100K cathode resistor (1.5mA plate current)
      2. Cathode follower with a 1.5mA constant current sink (CCS)
      3. Cathode follower with 60k i.e. 2.5mA plate current to try to lower output impedance and increase drive current
      4. Cathode follower with a 2.5mA constant current sink
    Conclusions:
    1. The 100k case only manages approx 20 Vpp out. This might be enough, it depends on the levels in your particular design. If your signal is small enough this is the way to go. Some compression.
    2. The 1.5mA CCS does a little better at 28 Vpp (at the expense of complexity). This happens because the high AC impedance of the CCS means all the signal current flows through the load. Least compression.
    3. The 60K case gets you to 72 Vpp but there is significant compression due to grid current.
    4. The 2.5mA CCS has 112 Vpp out, with moderate compression.
    5. The CF output impedance is so low that interaction between tone stacks will be minimal. I can't see that being an issue in practice.
    'course this is just a simulation and is therefore subject to the setup, interpretation, models used, my mistakes and other random effects. Just my opinion on compression. Some might argue more is better
  25. #25
    Cheshire, UK
    2,291
    Received: 593/4
    Given: 308/0
    16
    Sorry, I don't understand the question. It was just an idea. Are you thinking I'd have a spare triode because I'd have to add a 12Ax7 for the extra CF? In that case I'd use the existing 12AX7 for a parallel gain stage and the added 12AX7 for the two CFs.
  26. #26
    Supporting Member
    Sep 2007
    3,157
    Received: 191/0
    17
    1. The CF output impedance is so low that interaction between tone stacks will be minimal. I can't see that being an issue in practice.
    If the CF runs out of current for any reason then it no longer has low impedance, and there is interaction. Since a tone stack stores energy, the interaction can take the form of mutually altered frequency responses.
  1. Designing tone stacks.
    By tubeamptech in forum Theory & Design
    Last Post: 03-04-2015, 05:28 PM
  2. Cathode follower and heater to cathode voltage? 12AX7
    By CoffeeTones in forum Guitar Amps
    Last Post: 03-17-2013, 11:15 PM
  3. Tone Stacks
    By Gingertube in forum Theory & Design
    Last Post: 07-27-2011, 01:14 PM
  4. Vibroking Stage 1 cathode follower - tone?
    By Alex R in forum Theory & Design
    Last Post: 07-15-2008, 05:22 PM
  5. --tchless tone stacks
    By drewl in forum Theory & Design
    Last Post: 09-27-2007, 04:39 AM
